[cgal-discuss] How to get one boundary and one hole from a self-intersected polygon
- To:
- Subject: [cgal-discuss] How to get one boundary and one hole from a self-intersected polygon
- Date: Thu, 6 May 2010 10:58:09 -0700 (PDT)
Hi,
Now I am going to use CGAL to do boolean operation for 2D polygons.
Before boolean operation, I need to make simple polygon with holes from an
abnormal polygon.
I expect Arrangement from CGAL handles this problem using sweep-line
algorithm.
However, Arrangement gives a different shapes from what I expected.
Here is an example in which one polygon has a self-intersected region and I
expect that Arrangement has two outer boundaries (one for polygon boundary
and another for hole). But the result is three outer boundaries including an
overlap area by self-intersected. Would you please let me know how to get
the simple polygon with holes from this kind of polygon with
self-intersected?
Thanks,
Hyungon Kim
#include <iostream>
#include <list>
using namespace std;
#include <CGAL/basic.h>
#include <CGAL/Gmpq.h>
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Arr_segment_traits_2.h>
#include <CGAL/Arr_linear_traits_2.h>
#include <CGAL/Arr_polyline_traits_2.h>
#include <CGAL/Arrangement_2.h>
typedef CGAL::Lazy_exact_nt<CGAL::Gmpq> FT;
typedef CGAL::Simple_cartesian<FT>
cgalKernel;
typedef CGAL::Arr_segment_traits_2<cgalKernel> Segment_Traits2;
typedef CGAL::Arr_polyline_traits_2<Segment_Traits2> Traits2;
typedef Traits2::Point_2 Point2;
typedef Traits2::Segment_2 Segment2;
typedef Traits2::Curve_2 Polyline2;
typedef CGAL::Arrangement_2<Traits2> Arrangement2;
// Print all neighboring vertices to a given arrangement vertex.
template<class Arrangement>
void print_neighboring_vertices(typename Arrangement::Vertex_const_handle v)
if (v->is_isolated())
std::cout << "The vertex (" << v->point() << ") is isolated" <<
std::endl;
return;
typename Arrangement::Halfedge_around_vertex_const_circulator first,
curr;
typename Arrangement::Vertex_const_handle u;
std::cout << "The neighbors of the vertex (" << v->point() << ") are:";
first = curr = v->incident_halfedges();
do
// Note that the current halfedge is (u -> v):
u = curr->source();
std::cout << " (" << u->point() << ")";
++curr;
} while (curr != first);
std::cout << std::endl;
return;
// Print all vertices (points) and edges (curves) along a connected
component
// boundary.
void print_ccb(typename Arrangement::Ccb_halfedge_const_circulator circ)
typename Arrangement::Ccb_halfedge_const_circulator curr = circ;
typename Arrangement::Halfedge_const_handle he;
std::cout << "(" << curr->source()->point() << ")";
do
he = curr;
std::cout << " [" << he->curve() << "] "
<< "(" << he->target()->point() << ")";
++curr;
} while (curr != circ);
return;
// Print the boundary description of an arrangement face.
void print_face(typename Arrangement::Face_const_handle f)
// Print the outer boundary.
if (f->is_unbounded())
std::cout << "Unbounded face. " << std::endl;
else
std::cout << "Outer boundary: ";
print_ccb<Arrangement> (f->outer_ccb());
// Print the boundary of each of the holes.
typename Arrangement::Hole_const_iterator hole;
int index = 1;
for (hole = f->holes_begin(); hole != f->holes_end(); ++hole, ++index)
std::cout << " Hole #" << index << ": ";
print_ccb<Arrangement> (*hole);
// Print the isolated vertices.
typename Arrangement::Isolated_vertex_const_iterator iv;
for (iv = f->isolated_vertices_begin(), index = 1;
iv != f->isolated_vertices_end(); ++iv, ++index)
std::cout << " Isolated vertex #" << index << ": "
<< "(" << iv->point() << ")" << std::endl;
return;
// Print the given arrangement.
void print_arrangement(const Arrangement& arr)
CGAL_precondition (arr.is_valid());
// Print the arrangement vertices.
typename Arrangement::Vertex_const_iterator vit;
std::cout << arr.number_of_vertices() << " vertices:" << std::endl;
for (vit = arr.vertices_begin(); vit != arr.vertices_end(); ++vit)
std::cout << "(" << vit->point() << ")";
if (vit->is_isolated())
std::cout << " - Isolated." << std::endl;
else
std::cout << " - degree " << vit->degree() << std::endl;
// Print the arrangement edges.
typename Arrangement::Edge_const_iterator eit;
std::cout << arr.number_of_edges() << " edges:" << std::endl;
for (eit = arr.edges_begin(); eit != arr.edges_end(); ++eit)
std::cout << "[" << eit->curve() << "]" << std::endl;
// Print the arrangement faces.
typename Arrangement::Face_const_iterator fit;
std::cout << arr.number_of_faces() << " faces:" << std::endl;
for (fit = arr.faces_begin(); fit != arr.faces_end(); ++fit)
print_face<Arrangement> (fit);
return;
int main()
Arrangement2 arr;
std::list<Point2> points;
// case5: with overlap area
points.clear();
points.push_back(Point2(0,0));
points.push_back(Point2(50,0));
points.push_back(Point2(50,30));
points.push_back(Point2(30,30));
points.push_back(Point2(30,10));
points.push_back(Point2(10,10));
points.push_back(Point2(10,40));
points.push_back(Point2(20,40));
points.push_back(Point2(20,20));
points.push_back(Point2(40,20));
points.push_back(Point2(40,50));
points.push_back(Point2(0,50));
Polyline2 pline(points.begin(), points.end());
insert(arr, pline);
print_arrangement(arr);
return 0;
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-get-one-boundary-and-one-hole-from-a-self-intersected-polygon-tp2133084p2133084.html
- [cgal-discuss] How to get one boundary and one hole from a self-intersected polygon, Hyungon Kim, 05/06/2010
- Re: [cgal-discuss] How to get one boundary and one hole from a self-intersected polygon, efif, 05/08/2010
- Re: [cgal-discuss] How to get one boundary and one hole from a self-intersected polygon, Ben Supnik, 05/08/2010
- [cgal-discuss] Re: How to get one boundary and one hole from a self-intersected polygon, Hyungon Kim, 05/10/2010
