cgal-discuss - Re: [cgal-discuss] how to integrate Delaunay_triangulation_3 into Alpha_shape_3
  • To:
  • Subject: Re: [cgal-discuss] how to integrate Delaunay_triangulation_3 into Alpha_shape_3
  • Date: Sat, 08 May 2010 13:17:56 +0200
Dear Song Lin,
you are computing the alpha shapes of a *regular* triangulation. Regular triangulations work with weighted points. The nearest vertex query is thus called nearest_power_vertex().
I see two possibilities: Either you use Delaunay triangulations instead of regular triangulations or you call nearest_power_vertex instead of nearest_vertex.
hope this helps
Manuel
On 08/05/10 09:30, Song Lin wrote:
Hi,
I was trying to use the function "dt.nearest_vertex(Point p)". And the
class "Delaunay_triangulation_3" was needed.
But I don't know how to integrate the class into my codes. The typedef
part of my codes are:
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kk;
typedef CGAL::Regular_triangulation_euclidean_traits_3<Kk> Gt;
typedef CGAL::Alpha_shape_vertex_base_3<Gt> Vb_as;
typedef CGAL::Triangulation_vertex_base_with_info_3<vertexinfo, Kk,
Vb_as> Vb;
typedef CGAL::Alpha_shape_cell_base_3<Gt> Cb_as;
typedef CGAL::Triangulation_cell_base_with_info_3<cellinfo, Kk, Cb_as>
Cb;
typedef CGAL::Triangulation_data_structure_3<Vb,Cb> Tds;
typedef CGAL::Regular_triangulation_3<Gt,Tds> Triangulation_3;
typedef CGAL::Alpha_shape_3<Triangulation_3> Alpha_shape_3;
What should I do to use the function Alpha_shape_3.nearest_vertex() in
my codes? Maybe it's naive but I was confused with the relationships
between "traits","data_structures",and "kernels"..
Best regards,
Lin
