cgal-discuss - Re: [cgal-discuss] how to integrate Delaunay_triangulation_3 into Alpha_shape_3
  • To:
  • Subject: Re: [cgal-discuss] how to integrate Delaunay_triangulation_3 into Alpha_shape_3
  • Date: Sat, 08 May 2010 21:18:51 +0800
I tried "nearest_power_vertex()" and it works. Thanks!
Lin
在 2010-05-08六的 13:17 +0200,Manuel Caroli写道:
> Dear Song Lin,
> you are computing the alpha shapes of a *regular* triangulation. Regular
> triangulations work with weighted points. The nearest vertex query is
> thus called nearest_power_vertex().
> I see two possibilities: Either you use Delaunay triangulations instead
> of regular triangulations or you call nearest_power_vertex instead of
> nearest_vertex.
> hope this helps
> Manuel
> On 08/05/10 09:30, Song Lin wrote:
> > Hi,
> > I was trying to use the function "dt.nearest_vertex(Point p)". And the
> > class "Delaunay_triangulation_3" was needed.
> > But I don't know how to integrate the class into my codes. The typedef
> > part of my codes are:
> > typedef CGAL::Exact_predicates_inexact_constructions_kernel Kk;
> > typedef CGAL::Regular_triangulation_euclidean_traits_3<Kk> Gt;
> > typedef CGAL::Alpha_shape_vertex_base_3<Gt> Vb_as;
> > typedef CGAL::Triangulation_vertex_base_with_info_3<vertexinfo, Kk,
> > Vb_as> Vb;
> > typedef CGAL::Alpha_shape_cell_base_3<Gt> Cb_as;
> > typedef CGAL::Triangulation_cell_base_with_info_3<cellinfo, Kk, Cb_as>
> > Cb;
> > typedef CGAL::Triangulation_data_structure_3<Vb,Cb> Tds;
> > typedef CGAL::Regular_triangulation_3<Gt,Tds> Triangulation_3;
> > typedef CGAL::Alpha_shape_3<Triangulation_3> Alpha_shape_3;
> > What should I do to use the function Alpha_shape_3.nearest_vertex() in
> > my codes? Maybe it's naive but I was confused with the relationships
> > between "traits","data_structures",and "kernels"..
> > Best regards,
> > Lin
Center of Computational and Systems Biology,
Institute of Biophysics, CAS.
15 Datun Road, Chaoyang District
Beijing, 100101
P.R.China
