cgal-discuss - Re: [cgal-discuss] Nearest Neighbor Search
  • To:
  • Subject: Re: [cgal-discuss] Nearest Neighbor Search
  • Date: Tue, 18 May 2010 22:05:05 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:content-type; b=Rof2TkFlBXgqvlXZfObw2BFAICf1vaj1hR7Td0INPObXOGHPfDiND3W9RBc8H8BhFe eKq93BLIdKbgE9qE30CYDWD38uYfLp/xiiDHkF6vxByk1yyAla7M/1x78DLQcGVPDAQL IJvPT35b067jpM55bT1JDHPRsF6cj5j8Hatug=
Hello,
On Tue, May 18, 2010 at 7:16 PM, Panagiotis Foteinos <> wrote:
Hello yall.
I would like to compute the Hausdorff distance of two 3D point sets. I am thinking of using the K nearest neighbor algorithm of CGAL with K equal to 1 for each point on the first set and for each point on the second set (two-sided Hausdorff distance).
The problem sounds interesting. But, instead of finding nearest neighbor for each point, some pre-process might be more efficient. For example, construct convex hulls for both sets and test whether they are intersected. If not, we only need to consider boundary vertex; if yes, points in the intersection parts would be primary and voronoi diagram might be helpful.
Just a quick thought... You might already have a better idea. =]
Best,
~Sophie
Don't dream it, Do it!
