- To:
- Subject: Re: [cgal-discuss] Nearest Neighbor Search
- Date: Thu, 20 May 2010 12:52:40 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=dSElrVaLrjqhgzx5S3AuRx7vk+rHQJZfDqr75bC3uCQELHP7yiQQKcfK/pkxEtoZQy y5I7CdteTKzfsEBALHiEM8p8rAkwpHfMQu9UFnwEU1mev6e4TzinO+9Qhf+8ShQMR2CH 0KDDhky5MaoIwvRNpZASV/9jrHE6wfTrNcziY=
Why Delaunay triangulation is needed?
2010/5/20, Panagiotis Foteinos
> Thank you for your reply.
> It seems that the best way is to construct the Delaunay triangulation of
> these two point sets and then ask for the nearest vertex of the first set
> from any point of the other. An initial spatial reordering of the point sets
> (before they are inserted into the Delaunay triangulation) will speed up
> things. Also, different queries do not change the underlying Delaunay
> structure (this is not the case for the K-neighbor search).
> Regards,
> Panagiotis Foteinos
> On Wed, May 19, 2010 at 9:21 AM, 杨成林
> wrote:
>> The spatial searching package in CGAL is not very efficient, though I have
>> not test the new version. ANN <http://www.cs.umd.edu/%7Emount/ANN/> is a
>> good nearest neighbor searching package, and Zhou has suggested
>> STANN<http://sites.google.com/a/compgeom.com/stann/>.
>> To compute Hausdorff distance, if you implement the search algorithm
>> yourself, you can terminate the search early to save time. Let d be the
>> current hausdorff distance, then if the search process get distance less
>> than d, the search can be terminated.
>> 2010/5/19 Panagiotis Foteinos
>> Hello yall.
>>> I would like to compute the Hausdorff distance of two 3D point sets. I am
>>> thinking of using the K nearest neighbor algorithm of CGAL with K equal
>>> to 1
>>> for each point on the first set and for each point on the second set
>>> (two-sided Hausdorff distance).
>>> Each point set is expected to contain no more than 100,000 points.
>>> Has anyone benchmarked the K nearest neighbor package? Is it reasonably
>>> fast? Any comments would be appreciated.
>>> Best Regards,
>>> Panagiotis Foteinos
>> 杨成林
>> Yang Chenglin
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
杨成林
Yang Chenglin
- [cgal-discuss] Nearest Neighbor Search, Panagiotis Foteinos, 05/19/2010
- Re: [cgal-discuss] Nearest Neighbor Search, Sophie Che, 05/19/2010
- Re: [cgal-discuss] Nearest Neighbor Search, 杨成林, 05/19/2010
- Re: [cgal-discuss] Nearest Neighbor Search, Panagiotis Foteinos, 05/19/2010
- Re: [cgal-discuss] Nearest Neighbor Search, 杨成林, 05/20/2010
- Re: [cgal-discuss] Nearest Neighbor Search, Panagiotis Foteinos, 05/20/2010
- Re: [cgal-discuss] Nearest Neighbor Search, Fei (Sophie) Che, 05/20/2010
