cgal-discuss - [cgal-discuss] Boost:: STATIC_ASSERTION_FAILURE when instantiated tetrahedron
  • To:
  • Subject: [cgal-discuss] Boost:: STATIC_ASSERTION_FAILURE when instantiated tetrahedron
  • Date: Thu, 20 May 2010 06:52:43 -0700 (PDT)
Hello,
I would like to create a 3D mesh from a polyhedral domain, like in the
example mesh_polyhedral_domain.cpp
After I want make a cycle on each cell in order to transform each cell in a
tetrahedron. The tetrahedron class would be used to calculate geometrical
properties of the cells.
http://www.cgal.org/Manual/3.2/doc_html/cgal_manual/Kernel_23_ref/Class_Tetrahedron_3.html
CGAL::Tetrahedron_3<K> is constructed by
Tetrahedron_3<Kernel> t ( Point_3<Kernel> p0,
Point_3<Kernel> p1,
Point_3<Kernel> p2,
Point_3<Kernel> p3);
introduces a tetrahedron t with vertices p0, p1, p2 and p3.
So I modify the mesh_polyhedral_domain.cpp example with :
#include <CGAL/Tetrahedron_3.h>
// Tetrahedron
typedef CGAL::Tetrahedron_3<K> Tetrahedron_3;
typedef K::Point_3 Point_3;
int main()
// Here create c3t3...
Point_3 p0,p1,p2,p3;
int mesh_cells_counter =0 ;
for(C3t3::Cell_iterator cit=c3t3.cells_begin(); cit != c3t3.cells_end();
++cit)
if(c3t3.is_in_complex(cit))
++mesh_cells_counter;
p0=(cit->vertex(0)->point());
p1=(cit->vertex(1)->point());
p2=(cit->vertex(2)->point());
p3=(cit->vertex(3)->point());
std::cout << (cit->vertex(1)->point()) << std::endl;
Tetrahedron_3 tetra (p0,p1,p2,p3);
// std::cout << "Number of cells: " << mesh_cells_counter << std::endl;
return 0;
But the compilation failed and return BOOST::STATIC_ASSERTION_FAILURE and I
really don't understand the problem.
In file included from /usr/include/CGAL/user_classes.h:48,
from /usr/include/CGAL/squared_distance_2_1.h:30,
from /usr/include/CGAL/Circle_2_Circle_2_intersection.h:30,
from /usr/include/CGAL/intersection_2_3.h:29,
from /usr/include/CGAL/intersection_2.h:31,
from /usr/include/CGAL/intersections.h:29,
from /usr/include/CGAL/AABB_intersections.h:20,
from
/home/ben/CGAL/CGAL-3.6/examples/BenWork/mesh_polyhedral_domain_ben.cpp:1:
/usr/include/CGAL/Tetrahedron_3.h: In instantiation of
‘CGAL::Tetrahedron_3<K>’:
/home/ben/CGAL/CGAL-3.6/examples/BenWork/mesh_polyhedral_domain_ben.cpp:90:
instantiated from here
/usr/include/CGAL/Tetrahedron_3.h:42: error: invalid application of ‘sizeof’
to incomplete type ‘boost::STATIC_ASSERTION_FAILURE<false>’
make[2]: ***
[CMakeFiles/mesh_polyhedral_domain_ben.dir/mesh_polyhedral_domain_ben.o]
Errore 1
make[1]: *** [CMakeFiles/mesh_polyhedral_domain_ben.dir/all] Errore 2
Thanks,
Benjamin
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Boost-STATIC-ASSERTION-FAILURE-when-instantiated-tetrahedron-tp2224577p2224577.html
