Re: [cgal-discuss] Boost:: STATIC_ASSERTION_FAILURE when instantiated tetrahedron
- To:
- Subject: Re: [cgal-discuss] Boost:: STATIC_ASSERTION_FAILURE when instantiated tetrahedron
- Date: Thu, 20 May 2010 17:13:42 +0200
On Thursday 20 May 2010 17:05:04 Benjamin Bouscasse wrote:
> OK, it compiles well now!
> Thanks for the tip, so it means that the C3T3::iterator runs only on finite
> cells?
> Because for a similar application in 2D I have to add an
> "if(fit->is_in_domain())" to select only the faces inside the meshed
> domain. So I thought that "cit->is_in_complex()" was the 3D equivalent.
The range [c3t3.cells_begin(), c3t3.cells_end()[ gives only cells that are in
the 3D complex, as if is_in_complex() had been tested on each finite cells of
the triangulation.
Laurent Rineau, PhD
- [cgal-discuss] Boost:: STATIC_ASSERTION_FAILURE when instantiated tetrahedron, N2a, 05/20/2010
- Re: [cgal-discuss] Boost:: STATIC_ASSERTION_FAILURE when instantiated tetrahedron, Stephane Tayeb, 05/20/2010
- Re: [cgal-discuss] Boost:: STATIC_ASSERTION_FAILURE when instantiated tetrahedron, Benjamin Bouscasse, 05/20/2010
- Re: [cgal-discuss] Boost:: STATIC_ASSERTION_FAILURE when instantiated tetrahedron, Laurent Rineau (GeometryFactory), 05/20/2010
