- To:
- Subject: Re: [cgal-discuss] Re: Mesh 3D - nodes subdomain index
- Date: Thu, 20 May 2010 16:45:15 +0200
Ianic wrote:
To make things clearer, I am talking here about the "File_medit.h"
functionality. Basically, when I output the Vertices section of a .mesh
file, I want to exclude the nodes for which ( get(vertex_pmap, vit) == -1 ).
I wanted to do this because I thought these vertices would be unreferenced
in the sense that they would not belong to any cell of c3t3 complex. But
this is not the case and I wonder why.
Unfortunately, the File_medit.h file is overall too cryptic for my level of
C++ proficiency, but I believe that get(vertex_pmap, vit) function should
give a subdomain index of any cell incident to the vertex. In my case it
sometimes gives "-1" but I have checked that some of those "-1" vertices
belong to cells of c3t3 for which get(cell_pmap, cit) gives "2".
Hi,
I did some tests, and you I found the same behavior as you: some vertices of the c3t3 of dimension 2 are not incident to any facet. This seems to be a bug, I will look at it.
As a quick fix, I could say that you could just ignore the vertices tags of the .mesh output, as they are not very accurate:
+ for dim=3 vertices, the tag is the tag of any of its adjacent cell
+ for dim=2 vertices, the tag is the tag of *one* of its adjacent surface facet (one 'surface' vertex could be incident to surface facets with different indices)
However, this behaviour raised up in my case when I used CGAL::perturb_mesh_3. Could you please provide me more details about how you generate your mesh ?
Thank you,
Best,
Stéphane.
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
- [cgal-discuss] Mesh 3D - nodes subdomain index, Ianic, 05/18/2010
- [cgal-discuss] Re: Mesh 3D - nodes subdomain index, Ianic, 05/18/2010
- Re: [cgal-discuss] Re: Mesh 3D - nodes subdomain index, Stephane Tayeb, 05/20/2010
- [cgal-discuss] Re: Mesh 3D - nodes subdomain index, Ianic, 05/20/2010
- Re: [cgal-discuss] Re: Mesh 3D - nodes subdomain index, Stephane Tayeb, 05/21/2010
- [cgal-discuss] Re: Mesh 3D - nodes subdomain index, Ianic, 05/21/2010
