- To:
- Subject: Re: [cgal-discuss] Re: Mesh 3D - nodes subdomain index
- Date: Fri, 21 May 2010 11:14:12 +0200
Hi Ianic,
Ianic wrote:
Dear Stephane,
Thank you for your reply. I mesh a single-domain geometry that has one cell
family and one facet family, i.e. boundary of my domain. I essentially
follow the liver example in doing this, and I only change the meshing
criteria but keep the optimization parameters at their default values. I
believe it implies that there is a perturbation step at the end.
You are right, there is a perturbation step (and an exudation one) in the default case.
In my case I actually relied on vertices' tags, because I have to:
- remove unreferenced vertices that are not part of any cell (our finite
element code won't accept a mesh otherwise). I thought it would be easier to
NOT output them in CGAL in the first place. For that I added a small if()
check in the File_medit.h file to write out a vertex only if its tag is not
-1.
- I also need to identify what vertices lie on a boundary, i.e. belong to
facet. My understanding was that if a node belongs to a boundary facet it
means that, following your terminology, it has dim=2 and therefore it will
have a facet tag (which is ok since I only have one facet family).
As a reference, my output mesh had appr. 900 000 vertices, of which 430-ish
had a tag of "-1" and of those only 2 belonged to a c3t3 cell.
I understand your needs. I did more experiments and we thought a bit about your problem. We found that, depending on the input data, our algorithm could generate isolated points.
I suggest that you use the function of the attached file to clean-up your c3t3, then output your mesh as you did. The vertices with -1 index in the generated file should be the vertices that are not incident to any tetrahedron of the mesh. The vertices with dim=2 (and thus your facet tag) should be the vertices which lie on the boundary of the mesh.
You could also directly use the various iterator of the c3t3 object (and its embedded triangulation) to write your output.
Best,
Stéphane.
PS: if your data is not confidential, I would be glad if you could send it to me so that I can analyze it.
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
template <typename C3T3> void clean_c3t3(C3T3& c3t3) { typedef typename C3T3::Triangulation Tr; typedef typename C3T3::Cell_handle Cell_handle; typedef typename C3T3::Facet Facet; typedef typename Tr::Finite_vertices_iterator Fvi; const Tr& tr = c3t3.triangulation(); if ( tr.dimension() < 3 ) { return; } // Iterate on vertices and fix dimension for ( Fvi vit = tr.finite_vertices_begin(), end = tr.finite_vertices_end() ; vit != end ; ++vit ) { typename std::vector<Facet> facets; tr.finite_incident_facets(vit, std::back_inserter(facets)); CGAL_assertion(!facets.empty()); // Look for the first surface facet typename std::vector<Facet>::iterator it_facet = facets.begin(); while ( it_facet != facets.end() && !c3t3.is_in_complex(*it_facet++) ){} // vit is on the surface: set dimension and break if ( it_facet != facets.end() ) { c3t3.set_dimension(vit,2); continue; } // Look for the first interior cell typename std::vector<Cell_handle> cells; tr.finite_incident_cells(vit,std::back_inserter(cells)); CGAL_assertion(cells.begin() != cells.end()); if ( c3t3.is_in_complex(*cells.begin()) ) { c3t3.set_dimension(vit,3); continue; } // vit is not part of the complex c3t3.set_dimension(vit,-1); } }
- [cgal-discuss] Mesh 3D - nodes subdomain index, Ianic, 05/18/2010
- [cgal-discuss] Re: Mesh 3D - nodes subdomain index, Ianic, 05/18/2010
- Re: [cgal-discuss] Re: Mesh 3D - nodes subdomain index, Stephane Tayeb, 05/20/2010
- [cgal-discuss] Re: Mesh 3D - nodes subdomain index, Ianic, 05/20/2010
- Re: [cgal-discuss] Re: Mesh 3D - nodes subdomain index, Stephane Tayeb, 05/21/2010
- [cgal-discuss] Re: Mesh 3D - nodes subdomain index, Ianic, 05/21/2010
