[cgal-discuss] Re: Calculating area of polygon (Gps_traits_2::Polygon_with_holes_2)
- To:
- Subject: [cgal-discuss] Re: Calculating area of polygon (Gps_traits_2::Polygon_with_holes_2)
- Date: Tue, 25 May 2010 09:10:23 -0700 (PDT)
Thank you for your suggestion,
i had something similar in mind, the problem was that there is no function
for polygons with arcs. If anybody wants to know, I managed to solve to
problem by constructing internal polygon from all the X_monotone_curve_2
source points. And than, after calculating that area (which is simple), i
calculated areas closed between arcs and internal polygon.
Cheers!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Calculating-area-of-polygon-Gps-traits-2-Polygon-with-holes-2-tp2225954p2230269.html
- [cgal-discuss] Calculating area of polygon (Gps_traits_2::Polygon_with_holes_2), nenol10, 05/21/2010
- Re: [cgal-discuss] Calculating area of polygon (Gps_traits_2::Polygon_with_holes_2), zjkg, 05/25/2010
- [cgal-discuss] Re: Calculating area of polygon (Gps_traits_2::Polygon_with_holes_2), nenol10, 05/25/2010
