Re: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator
- To:
- Subject: Re: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator
- Date: Tue, 25 May 2010 10:42:24 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=ZsWLiQyii0UoBwbNLYXAI2p9m7z4gtG8cLl7U1cRrKeP4riT6SjIPxLrbBeAzz97e9 ggEv6X94iLgfscECGd2n/I5UCp9rjjJ1GnQGSQyuXX6JC70GQWWEuRI22uiA/3dwT42u H21sme3raU9z4ow71fCrTTMW0iQU1/5lZlYik=
Hi Laurent,
I am also experimenting with this mesher stuff, the goal is to generate a manifold surface/polyhedron from non-manifold surface/polydedron and then convert the manifold surface/polyderon to CGAL's Nef_polyhedron. I have made some progress to get a Nef_polyhedron, but it seems that Nef_polyhedron.is_valid() returns false though the polyhedron itself is both closed and valid and the conversion from polyhedron to Nef_polyhedron is successful. The attached is the input data which is non_manifold polyhedron. The question is: is it possible to generate a valid Nef_polyhedron using this pipeline?
"Again, I know that the problematic feature is the coplanar facets at the bottom of the object. We have solutions for that, but the merge with the branch of CGAL-3.6 is not easy." Can you please share the solution if it's O.K.?
Cheers.
Joe
On Tue, May 25, 2010 at 2:48 AM, Laurent Rineau (GeometryFactory) <laurent.rineau__CGAL@file:///E:/Temp/TubeFix/InputPoly.offnormalesup.org> wrote:
On Friday 21 May 2010 09:27:10 fp2008 wrote:There are several issues.
> Hi Andreas,
> I attached three OFF files. The remeshing tool crashes quickly when
> processing box.off and glass-mug.off, though it gets stuck instead with
> flash.off.
** First, there is a non-exact use of the AABB_tree class, in the Polyhedron demo. Please apply the following patch:
--- demo/Polyhedron/Polyhedron_demo_remeshing_plugin_cgal_code.cpp.~BASE~ 2010-05-25 11:24:12.000000000 +0200
+++ demo/Polyhedron/Polyhedron_demo_remeshing_plugin_cgal_code.cpp 2010-05-21 15:12:43.000000000 +0200
@@ -110,10 +110,10 @@
// Types for meshing
-typedef CGAL::Simple_cartesian<double> Simple_cartesian_kernel;
+// typedef CGAL::Simple_cartesian<double> Simple_cartesian_kernel;
// input surface
-// typedef CGAL::Mesh_3::Robust_intersection_traits_3<Kernel> IGT;
-typedef CGAL::AABB_polyhedral_oracle<Polyhedron,Kernel,Simple_cartesian_kernel> Input_surface;
+typedef CGAL::Mesh_3::Robust_intersection_traits_3<Kernel> IGT;
+typedef CGAL::AABB_polyhedral_oracle<Polyhedron,Kernel,IGT> Input_surface;
// A base non-templated class, to allow
That will prevent the Surface_mesher from crashing on a simple cube surface. Actually, a cube a something particularly difficult to mesh:
- there are a lot of coplanar points,
- there are sharp edges (that the Surface_mesher package cannot mesh properly).
** Second, your file glass-mug.off is not a triangulated surface. Please use the menu entry Operations->Triangulate facets before launching the remeshing function.
** Third, your file flash.off is triangulated, but quite difficult to mesh: it has two cylindrical patches of surface that are very close from each other. It means that the least feature size of this surface
is very small. You need to decrease the sizing field by a magnitude. However, I agree there is a problem in the surface mesher, because I have not been able to mesh that object without the assertion. Again, I
Laurent Rineau, PhD
InputPoly.off
Description: Binary data
- [cgal-discuss] remeshing crash: a problem of the surface mesh generator, fp2008, 05/21/2010
- Re: [cgal-discuss] remeshing crash: a problem of the surface mesh generator, Andreas Fabri, 05/21/2010
- [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator, fp2008, 05/21/2010
- Re: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator, Laurent Rineau (GeometryFactory), 05/25/2010
- Re: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator, Joe C, 05/25/2010
- Re: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator, Joe C, 05/27/2010
- Re: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator, Stephane Tayeb, 05/27/2010
