cgal-discuss - Re: [cgal-discuss] MESH 3D, criteria and optimization to achieve mesh with almost constant volume
  • To:
  • Subject: Re: [cgal-discuss] MESH 3D, criteria and optimization to achieve mesh with almost constant volume
  • Date: Wed, 26 May 2010 13:34:30 +0200 (CEST)
  • Organization: Institut fuer Werkstoffe TU Braunschweig
Hi,
cannot really answer your question within CGAL, but be aware that the
mesh you create will not conform exactly to the polyhedron you start
with (i.e., nodes of the polyhedral mesh will not necessarily be nodes
of the 3D mesh - there is smoothing going on)
I have used both tetgen and netgen (you convert to off-files or
stl-files and mesh these structures).
Martin.
Hello,
No response, I hope this is not a stupid question !!!
So I try to semplify:
Why is the best way to obtain from a polyhedral domain a 3D mesh with almost
constant cell volume, and to be able to control in input that volume?
I would be very happy to have some tips, or indication of paper thesis
whatever!
Thanks,
Benjamin
2010/5/25 N2a
Hello,
I'm trying to generate a 3D mesh with cells of almost constant volume. I
obtain a correct result for a cube, meshing with the criteria given in the
manual Facet_ criteria (25,0.15,0.05) and Cell criteria (4,0.2) , and after
optimizing it with Lloyd algorithm.
I try to understand what is the best way to have a almost volume constant
tetrahedric mesh and if it is possible to set a criteria or a mathematical
relation between the criteria in order to control as a target the volume of
the cell.
My polyhedral domain will be quite complicated, like the internal part of a
ship hull.
I have some good results now but I would really like to have a generic
process that is able to generate the mesh whatever is the domain given only
in input the volume as a target.
I hope someone has a good strategy helping me to achieve this goal,
computation time is not a big problem.
Thanks in advance,
Benjamin
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/MESH-3D-criteria-and-optimization-to-achieve-mesh-with-almost-constant-volume-tp2229814p2229814.html
Priv.-Doz. Dr. Martin Bäker
Institut für Werkstoffe
Technische Universität Braunschweig
Langer Kamp 8
38106 Braunschweig
Germany
Tel.: 00-49-531-391-3073
Fax 00-49-531-391-3058
e-mail
