Re: [cgal-discuss] MESH 3D, criteria and optimization to achieve mesh with almost constant volume
- To:
- Subject: Re: [cgal-discuss] MESH 3D, criteria and optimization to achieve mesh with almost constant volume
- Date: Wed, 26 May 2010 18:41:23 +0200
If you build the mesh with mesh criteria including an explicit small enough cell_size, you will get a mesh with a uniform sizing field. This means that all the cells will have nearly the same radius of their circumsphere. For this to be true, the cell size parameter should be small enough compared to the details in the domain boundary. Then, if the mesh is optimized, the volume of each cell should be not too small with respect to the volume of its circumsphere .... so that you should get cells with about the same volume ... Benjamin Bouscasse wrote: Hello, -- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] MESH 3D, criteria and optimization to achieve mesh with almost constant volume, N2a, 05/25/2010
- Re: [cgal-discuss] MESH 3D, criteria and optimization to achieve mesh with almost constant volume, Benjamin Bouscasse, 05/26/2010
- Re: [cgal-discuss] MESH 3D, criteria and optimization to achieve mesh with almost constant volume, Martin Baeker, 05/26/2010
- Re: [cgal-discuss] MESH 3D, criteria and optimization to achieve mesh with almost constant volume, Mariette Yvinec, 05/26/2010
