cgal-discuss - Re: [cgal-discuss] performance of finite_adjacent_vertices
  • To:
  • Subject: Re: [cgal-discuss] performance of finite_adjacent_vertices
  • Date: Wed, 26 May 2010 10:38:39 -0400
Hi Sebastien,
I'm terribly sorry for wasting your time. I just realized that I had an extra line in the middle of the loop that copies the triangulation, left over from a test I was running and hence the slow down. ( Sleep deprivation => doing stupid things...) As expected, getting adjacent vertices takes sub-second time.
Thanks,
Frankie
Sebastien Loriot (GeometryFactory) wrote:
Frankie Li wrote:
Hi all,
I'm trying to traverse all neighbors of each vertex in a regular triangulation, and naively, I've done something like this:
// pseudo-code
for( Finite_vertex_iterator it = tr.finite_vertices_begin();
it != tr.finite_vertices_end(); ++ it )
vector<Vertex_handle> Ngb_vertices;
tr.finite_adjacent_vertices( it, std::back_inserter( Ngb_vertices ));
However, I found it to be surprisingly slow. I have approximately 15000 vertices, and I'm using Exact_predicates_inexact_constructions_kernel. (It takes about 3000 seconds to go through the loop above for 15000 vertices. I'm running on a Core 2 Quad machine.)
Any advice is welcomed! Thanks!
Frankie
Hello,
what you report is quite strange, because this is a combinatoric operation usually fast. I just make a quick test with 4500 weighted points and without any optimisation the timing is less 0.03s.
Can you test the program joint (it expects a file with line x y z radius as first argument) and tell us about the running time.
S.
