[cgal-discuss] Re: fatal error LNK1104: can not open file 'CGAL_Qt4-vc90-mt-gd.lib'
- To:
- Subject: [cgal-discuss] Re: fatal error LNK1104: can not open file 'CGAL_Qt4-vc90-mt-gd.lib'
- Date: Fri, 11 Jun 2010 02:24:15 -0700 (PDT)
This is libary CGAL with Qt4
When you install CGAL, you have to install Qt4 in order to get this file.
and at install CGAL steps,
1. cmake .
and set the Qt4 configure corrently.
or
2. go to $(CGAL_DIR)/src/CGALQt4
cmake . // build CGALQt only
You will be able to complie and get the file 'CGAL_Qt4-vc90-mt-gd.lib' in $(CGAL)/lib
2010/6/11 Hulusi [via cgal-discuss] <[hidden email]>
Hi,
When I try to build an example, the building fail and I have this error :
I searched this file in my hard disc but I was not able to find it.
Do you know how to get it, and what is this?
Thank you for your help
Best reagrds
Hulusi
View message @ http://cgal-discuss.949826.n4.nabble.com/fatal-error-LNK1104-can-not-open-file-CGAL-Qt4-vc90-mt-gd-lib-tp2251501p2251501.html
To start a new topic under cgal-discuss, email [hidden email]
To unsubscribe from cgal-discuss, click here.
View this message in context: Re: fatal error LNK1104: can not open file 'CGAL_Qt4-vc90-mt-gd.lib'
- [cgal-discuss] fatal error LNK1104: can not open file 'CGAL_Qt4-vc90-mt-gd.lib', Hulusi, 06/11/2010
- Re: [cgal-discuss] fatal error LNK1104: can not open file 'CGAL_Qt4-vc90-mt-gd.lib', Andreas Fabri, 06/11/2010
- [cgal-discuss] Re: fatal error LNK1104: can not open file 'CGAL_Qt4-vc90-mt-gd.lib', Chad Liu, 06/11/2010
- [cgal-discuss] Re: fatal error LNK1104: can not open file 'CGAL_Qt4-vc90-mt-gd.lib', Hulusi, 06/11/2010
