[cgal-discuss] Re: fatal error LNK1104: can not open file 'CGAL_Qt4-vc90-mt-gd.lib'
- To:
- Subject: [cgal-discuss] Re: fatal error LNK1104: can not open file 'CGAL_Qt4-vc90-mt-gd.lib'
- Date: Fri, 11 Jun 2010 03:00:12 -0700 (PDT)
thank you for all reply,
I have built CGALQt in /src/CGALQt4
I had this error
Build type: Debug
USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR
-D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE
-D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except-
/D_DEBUG /MDd /Zi /Ob0 /Od /RTC1'
USING EXEFLAGS = ' /STACK:10000000 /machine:X86 /debug /INCREMENTAL:YES'
Targetting Visual Studio 9 2008
Target build enviroment supports auto-linking
Using VC90 compiler.
Generator uses intermediate configuration directory: $(OutDir)
CMake Error in
C:/CGAL/CGAL-3.6/src/CGALQt4/CMakeFiles/CMakeTmp/CMakeLists.txt:
Cannot find source file "print_QT4_version.cpp". Tried extensions .c .C
.c++ .cc .cpp .cxx .m .M .mm .h .hh .h++ .hm .hpp .hxx .in .txx
CMake Error: Internal CMake error, TryCompile generation of cmake failed
WARNING: QT4 found but could not compile print_QT4_version.cpp:
QT_INCLUDE_DIR=C:/Qt/4.6.2/include
QT_LIBRARIES=optimized;C:/Qt/4.6.2/lib/qtmain.lib;debug;C:/Qt/4.6.2/lib/qtmaind.lib;optimized;C:/Qt/4.6.2/lib/QtOpenGL4.lib;debug;C:/Qt/4.6.2/lib/QtOpenGLd4.lib;optimized;C:/Qt/4.6.2/lib/QtGui4.lib;debug;C:/Qt/4.6.2/lib/QtGuid4.lib;optimized;C:/Qt/4.6.2/lib/QtCore4.lib;debug;C:/Qt/4.6.2/lib/QtCored4.lib
QT_LIBRARY_DIR=C:/Qt/4.6.2/lib
USING QT4_VERSION = 'unknown'
OpenGL include:
OpenGL libraries: glu32;opengl32
OpenGL definitions:
Qt4 include: C:/Qt/4.6.2/include
Qt4 libraries:
Qt4 definitions: -DQT_DLL
moc executable: C:/Qt/4.6.2/bin/moc.exe
uic executable: C:/Qt/4.6.2/bin/uic.exe
Configuring incomplete, errors occurred!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/fatal-error-LNK1104-can-not-open-file-CGAL-Qt4-vc90-mt-gd-lib-tp2251501p2251564.html
- [cgal-discuss] fatal error LNK1104: can not open file 'CGAL_Qt4-vc90-mt-gd.lib', Hulusi, 06/11/2010
- Re: [cgal-discuss] fatal error LNK1104: can not open file 'CGAL_Qt4-vc90-mt-gd.lib', Andreas Fabri, 06/11/2010
- [cgal-discuss] Re: fatal error LNK1104: can not open file 'CGAL_Qt4-vc90-mt-gd.lib', Chad Liu, 06/11/2010
- [cgal-discuss] Re: fatal error LNK1104: can not open file 'CGAL_Qt4-vc90-mt-gd.lib', Hulusi, 06/11/2010
