cgal-discuss - Re: [cgal-discuss] 3D Boolean operation with float data
  • To:
  • Subject: Re: [cgal-discuss] 3D Boolean operation with float data
  • Date: Fri, 11 Jun 2010 16:12:05 +0200
What's the solution for the boolean operation see 2 points like: P1(2.1547
1.7897 2) P2 (2.1548 17897 2) identical?
You enter two different points, you get two different points.
What is wrong ?
You may try to preprocess your set of points, i.e. searching for nearest neighbor and replacing the coordinates sucha that they are the same for close points.
