- To:
- Subject: [cgal-discuss] shortest line between two lines in 3d
- Date: Fri, 11 Jun 2010 08:13:06 -0700 (PDT)
simple problem: i have two lines/rays in 3d and want to get the shortest line
that connects both (or similarly: the 3d point that has the shortest
distance to both lines).
i can only find the intersect method but this fits just for a special case.
Anybody knows if cgal can help here?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/shortest-line-between-two-lines-in-3d-tp2251943p2251943.html
- [cgal-discuss] shortest line between two lines in 3d, clemen, 06/11/2010
- RE: [cgal-discuss] shortest line between two lines in 3d, Vu, Khuong, 06/11/2010
- [cgal-discuss] RE: shortest line between two lines in 3d, clemen, 06/11/2010
- RE: [cgal-discuss] RE: shortest line between two lines in 3d, Vu, Khuong, 06/11/2010
- AW: [cgal-discuss] shortest line between two lines in 3d, Gärtner Bernd, 06/12/2010
- Re: AW: [cgal-discuss] shortest line between two lines in 3d, clemen, 06/14/2010
- RE: AW: [cgal-discuss] shortest line between two lines in 3d, Vu, Khuong, 06/14/2010
- [cgal-discuss] Finding points inside a rectangular region on space., Ricardo Bueno, 06/14/2010
- Re: [cgal-discuss] Finding points inside a rectangular region on space., Daniel Duque, 06/14/2010
- Re: [cgal-discuss] Finding points inside a rectangular region on space., Andreas Fabri, 06/14/2010
