cgal-discuss - [cgal-discuss] Re: using a Cgal example
  • To:
  • Subject: [cgal-discuss] Re: using a Cgal example
  • Date: Tue, 15 Jun 2010 03:26:42 -0700 (PDT)
Thank you
I heve copied the elephant.off file in the directory of the executable and I
set the its path as follows (the executable is located in the same
directory):
Polyhedron polyhedron;
std::ifstream input("C:\Documents and
Settings\user\Bureau\toto\Debug\elephant.off");
input >> polyhedron;
I have the same error
Best regards
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/using-a-Cgal-example-tp2255602p2255673.html
