- To:
- Subject: Re: [cgal-discuss] Re: using a Cgal example
- Date: Tue, 15 Jun 2010 08:27:32 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type; b=eODQ5hAojMqIlpqX4EoJDp4xRDN7X8FsOsTPAD/uVWH4UfyXOJnFFyfkjMnIrYo7jl 6M5KjmVvX5ZEdg8HqgMQkRkyGJJx9UsJuSnGaim3qlE/qu4QyPFwvELvwuJ8nOiQecq5 9oKPs3zA+hBybLW5LF8WepjG+Me6Im7esE610=
If the file is in the path of the executable, just do:
std::ifstream input("elephant.off");
input >> polyhedron;
-Ramin
On Tue, Jun 15, 2010 at 6:26 AM, Hulusi <> wrote:
Thank you
I heve copied the elephant.off file in the directory of the executable and I
set the its path as follows (the executable is located in the same
directory):
Polyhedron polyhedron;
std::ifstream input("C:\Documents and
Settings\user\Bureau\toto\Debug\elephant.off");
I have the same error
Best regards
View this message in context: http://cgal-discuss.949826.n4.nabble.com/using-a-Cgal-example-tp2255602p2255673.html
- [cgal-discuss] using a Cgal example, Hulusi, 06/15/2010
- Re: [cgal-discuss] using a Cgal example, Andreas Fabri, 06/15/2010
- [cgal-discuss] Re: using a Cgal example, Hulusi, 06/15/2010
- Re: [cgal-discuss] Re: using a Cgal example, Stephane Tayeb, 06/15/2010
- Re: [cgal-discuss] Re: using a Cgal example, Ramin H, 06/15/2010
