- To: <>
- Subject: [cgal-discuss] Need help about control_edge error during subdivision
- Date: Wed, 30 Jun 2010 18:01:02 -0400
- Organization: Purdue
Hi all, I am implementing subdivision with iteration. For each
facet, every edge is divided to the half (the middle point is added as new one
each edge) and making a new facet with a newly added point index with creating
Halfedge_handle for each new edge. And then again subdivide the new facet
in the same way; this makes the original triangle divided into 16 triangles (e.g.
4 subtriangles after the first iteration and those sub-triangles become 16 after
the second iteration). After this done, move to next facet to do the same
thing. However, an error occurs when making a new facet with the index of
vertex which is previously added. The error is related to Halfedge_handle . Halfedge_handle
h (see the below) returns NULL even though the indics (i0, i2, and i4) are
valid. Please help me if you know this problem. Thank you. *Code example B.begin_facet(); B.add_vertex_to_facet(i0); B.add_vertex_to_facet(i2); B.add_vertex_to_facet(i4); // i4 is the vertex index
previously added const Halfedge_handle& h = h.end_facet(); h->control_edge(false); <- ERROR occurs h->next()->control_edge(false); h->next()->next()->control_edge(false); ·
My goal is to create 16 subtriangles per facet at
a time. Samuel Kim |
- [cgal-discuss] Need help about control_edge error during subdivision, Kwangtaek Kim, 07/01/2010
