- To: , , ,
- Subject: [cgal-discuss] CGAL 3.6.1 Released, Computational Geometry Algorithms Library
- Date: Thu, 1 Jul 2010 12:03:26 +0200
The CGAL Open Source Project is pleased to announce the release 3.6.1 of
CGAL, the Computational Geometry Algorithms Library.
Version 3.6.1 is a bug-fix release for version 3.6. No new feature has
been added in 3.6.1. The following corrections have been made:
1. General
- Fix compilation errors with recent Boost versions (since 1.40).
- Initial support for the Microsoft Visual C++ compiler 10.0 (MSVC
2010).
For that support, CMake>=2.8.2 is required. Note also that the
compiler option "/bigobj" is necessary to compile some CGAL programs
with MSVC 2010. The Windows installer CGAL-3.6.1-Setup.exe does not
support VC++10. The source tarball must be downloaded instead and unpacked
manually. Precompiled binaries of GMP and MPFR must be downloaded from
GForge:
https://gforge.inria.fr/frs/?group_id=52
Download either gmp-5.0.1_and_mpfr-3.0.0_precompiled_i686.zip (for
32 bits compilers) or gmp-5.0.1_and_mpfr-3.0.0_precompiled_x64.zip (for
64 bits compilers) and unpack that zip file directly into the
sub-directory auxiliary/gmp/ of the unpacked sources directory
CGAL-3.6.1/. So that the files are put in
CGAL-3.6.1/auxilary/gmp/include/ and CGAL-3.6.1/auxilary/gmp/lib/. Then
continue with the CMake configuration and the compilation, as
instructed in the installation manual.
2. Polynomial
- Fix compilation errors with the Microsoft Visual C++ compiler and the
Intel C++ compiler.
3. Polyhedron
- Fix a compilation errors in demo/Polyhedron/:
- issue with the location of qglobal.h of Qt4 on MacOS X,
- missing texture.cpp, if TAUCS is used,
- Fix the location of built plugins of demo/Polyhedron/, when CGAL is
configured with WITH_demos=ON
- Fix a bug in test_facet function of the incremental builder:
the function did not test if while a new facet makes a vertex manifold,
no other facet incident to that vertex breaks the manifold property.
4. 3D Periodic Triangulations
- Fixed bug in the triangulation hierarchy for periodic triangulations.
5. 2D Mesh Generation
- Fix a bug that lead to precondition violation.
- Improve the user manual about the member function is_in_domain() of the
Face type.
- The 2D meshing process is now deterministic (sorting of bad faces no
longer relies on pointers comparisons).
6. 3D Mesh Generation
- Fix a linking errors (duplicate symbols) when <CGAL/refine_mesh_3.h> is
included in different compilation units.
7. Spatial Searching
- Fix a bug in <CGAL/Orthogonal_k_neighbor_search.h> when several
nearest neighbors are at the same distance from the query point.
8. IO Streams
- Fix a bug in <CGAL/IO/VRML_2_ostream.h> that generated VRML 2 files with
an invalid syntax for IndexedFaceSet nodes.
9. Triangulation_2
- Add missing Compare_distance_2 functor in trait classes
Triangulation_euclidean_traits_xy_3 Triangulation_euclidean_traits_yz_3
and Triangulation_euclidean_traits_xz_3. This was preventing calling
member function nearest_vertex of Delaunay_triangulation_2 instantiated
with one of these traits.
For further information and for downloading the library and its
documentation, please visit the CGAL web site: http://www.cgal.org/
Laurent Rineau, PhD
- [cgal-discuss] CGAL 3.6.1 Released, Computational Geometry Algorithms Library, Laurent Rineau (GeometryFactory), 07/01/2010
- Re: [cgal-discuss] CGAL 3.6.1 Released, Computational Geometry Algorithms Library, Lehtonen, Matti/HIIT, 07/02/2010
- Re: [cgal-discuss] CGAL 3.6.1 Released, Computational Geometry Algorithms Library, Laurent Rineau (GeometryFactory), 07/02/2010
- Re: [cgal-discuss] CGAL 3.6.1 Released, Computational Geometry Algorithms Library, Joachim Reichel, 07/02/2010
- Re: [cgal-discuss] CGAL 3.6.1 Released, Computational Geometry Algorithms Library, Joachim Reichel, 07/04/2010
