cgal-discuss - Re: [cgal-discuss] 3D meshing - bad tetrahedra
  • To:
  • Subject: Re: [cgal-discuss] 3D meshing - bad tetrahedra
  • Date: Fri, 09 Jul 2010 08:50:56 +0200
Ramin H wrote:
Hi everyone,
I am using the Meshe_3 in CGAL 3.6. The meshing criteria is as follows:
Cell Aspect Ratio: 3.0
Facet Angle: 25
And I have turned on Exuding. When I inspect the mesh, I can still see
plenty of tetrahedra that are violating the aspect ratio rule. I am using
the resulting mesh for a Finite Element Analysis and the quality of mesh has
a significant impact on the accuracy of the results.
How can I get rid of all (or most) of bad tetrahedra?
Thanks,
-Ramin
Hi Ramin,
After the mesh generation step, you should have a mesh that fulfills your criteria, i.e. every tetrahedron of the mesh should have a *radius-edge ratio <= 3* (is that what you call aspect ratio ?)
As the sliver exudation process tries to increase the smallest dihedral angle in the mesh, there is no guarantee that the radius-edge ratio would not decrease during exudation.
What are your criteria to consider a tetrahedron is bad ?
Best,
Stéphane.
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
