cgal-discuss - [cgal-discuss] Mesh Generation From a Segmented 3D Image - Input / output formats / write/read from txt
  • To:
  • Subject: [cgal-discuss] Mesh Generation From a Segmented 3D Image - Input / output formats / write/read from txt
  • Date: Tue, 13 Jul 2010 06:22:27 -0700 (PDT)
Hello all
i am new to CGAL and am trying to do Mesh Generation From a Segmented 3D
Image - input format is .lattice (a voxel based format here at university).
Output format should be a ASCII File with a list of nodes, elements (and
materials) and neighbours.
At the moment I am trying to find out how input and output files are
formatted but could not find any example files.
Can you tell me where to find a "*.mesh" and a "*.inr.gz" file
as used in the code example under "49.3.3 Mesh Generation From a Segmented
3D Image"
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Mesh_3/Chapter_main.html
or give me a link to a file format description? Or are the files all binary
and not really nice to look at? I have some trouble reading (and finding the
right) code to find out the data structure.
I will probably need to write a tool that converts the .lattice format to
CGALs input format (C3T3?) - but don't really understand how do that to
since i miss the descriptions. Same with the output .mesh file.
I found that the output format can be ASCII - and thats what i need ...
where do i set a parameter that lets CGAL save the mesh as an ASCII list of
nodes, elements (with material attribute) etc?
Due to the huuuge amount of data and functions in CGAL i have quite some
trouble to find a point to start with.
Many thanks for any help
regards
Alex
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesh-Generation-From-a-Segmented-3D-Image-Input-output-formats-write-read-from-txt-tp2287401p2287401.html
