cgal-discuss - Re: [cgal-discuss] problem with TAUCS
  • To:
  • Subject: Re: [cgal-discuss] problem with TAUCS
  • Date: Mon, 26 Jul 2010 18:00:43 +0200
  • Organization: INFOTERRA
You seem to have a conflict between 2 headers, which is not related of cmake.
I cannot much help you as the errors below occur in your code (in liblas/ folder).
Make sure that you have no min() or max() macro in your code.
Regards,
Laurent S.
wrote:
Hi,
i'm sorry, but i am not getting any progress on this. I didn't modify the
CMakeLists.txt (i don't know how to), but i also don't think that's the
problem.
I'm working with poisson_reconstruction_example.cpp on VC++ after runing
cmake.
It works fine.
Then i just include two new .hpp (these .hpp depend on many others .hpp
files),
and compile it. The error i get, is just about three lines of one .hpp
...sintax errors. But i already used those headers, and they don't have
errors.
Can this be some conflict with CMake? I don't know...
This is what i get:
c:\cgal-3.6\examples\surface_reconstruction_points_3\liblas/detail/utility.hpp(281)
: error C2589: '(' : illegal token on right side of '::'
c:\cgal-3.6\examples\surface_reconstruction_points_3\liblas/guid.hpp(414) : see
reference to function template instantiation 'T
liblas::detail::generate_random_byte<liblas::uint8_t>(void)' being compiled
with
T=liblas::uint8_t
: error C2059: syntax error : '::'
c:\cgal-3.6\examples\surface_reconstruction_points_3\liblas/detail/utility.hpp(282)
And these are the lines it is complaining about:
T const rmin = std::numeric_limits<T>::min();
T const rmax = std::numeric_limits<T>::max();
I'm getting really lost here...i'm sorry for the questions. And thanks again
for your help.
Best regards,
Cristóvão
Ce courrier électronique et toutes les pièces éventuellement jointes qu’il
contient sont CONFIDENTIELS et destinés exclusivement à l’usage de leur
destinataire. Si une erreur de transmission ou une adresse erronée a mal
dirigée ce courrier, merci d’en informer l’expéditeur en lui faisant une
réponse par courrier électronique dès réception. Si vous n’êtes pas le
destinataire de ce courrier, vous ne devez pas l’utiliser, le conserver, en
faire état, le distribuer, le copier, l’imprimer ou en révéler le contenu à
une tierce partie.
Ce courrier électronique est à usage strictement informatif et ne saurait
engager de quelque manière que ce soit SPOT IMAGE SA, ni ses filiales.
This e-mail and any attachments hereto are CONFIDENTIAL and intended solely
for the use of the addressee. If you have received this e-mail in error
please send it back to the person that sent it to you.
If you have received it in error, please notify the sender by return email.
If you are not the addressee of this email, you must not use, keep,
disseminate, copy, print or otherwise deal with it.
This email is for information only and will not bind SPOT IMAGE SA in any
contract or obligation, nor its subsidiaries.
