cgal-discuss - Re: [cgal-discuss] cmake build speed
  • To:
  • Subject: Re: [cgal-discuss] cmake build speed
  • Date: Thu, 29 Jul 2010 00:40:17 +0200
Hi,
>> Since cmake has proper dependency
>> analysis and the
>> generated makefiles only rebuild the source files that need
>> to get
>> rebuild, ccache won't help here, right?
> This depends upon whether you make clean or not on your project. My
> personal workflow seems to get about a 50% hit rate on the cache.
but why would one use "make clean" if you have proper dependency
tracking? Unless I'm missing something a simple "make" (without "make
clean") will recompile exactly those translation units that ccache can
not serve from the cache because the cached version is outdated.
Joachim
