- To:
- Subject: Re: [cgal-discuss] boost 1.43
- Date: Mon, 02 Aug 2010 12:52:33 +0200
Please contact the boost team to see why you cannot download
the library (I do not want to try to send an email with a 70Mb attachment).
S.
sara123 wrote:
hi Sebastien,
thanks alot for answering to my question.
i need to Boost C++ Libraries, i have tried to download it from internet, but because of my living area -my ip- I did not succeed to install it.Is it possible for you to send the boost 1.43 on my ID "[hidden email] </user/SendEmail.jtp?type=node&node=2310134&i=0>"?
thanks
sara
--- On Mon, 8/2/10, Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden email] </user/SendEmail.jtp?type=node&node=2310134&i=1>> wrote:
> From: Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden email] </user/SendEmail.jtp?type=node&node=2310134&i=2>>
> Subject: Re: meshing a simple polygon
> To: "sara123" <[hidden email] </user/SendEmail.jtp?type=node&node=2310134&i=3>>
> Date: Monday, August 2, 2010, 5:32 AM
> sara123 wrote:
> > I would like to meshing a simple polygon considering
> the scale of polygon,
> > who can help me
> Have a look at the examples in this chapter:
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Mesh_2/Chapter_main.html
> S.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
> View message @ http://cgal-discuss.949826.n4.nabble.com/meshing-a-simple-polygon-tp2309541p2309905.html <http://cgal-discuss.949826.n4.nabble.com/meshing-a-simple-polygon-tp2309541p2309905.html?by-user=t>
> To unsubscribe from meshing a simple polygon, click
> here.
View this message in context: boost 1.43 <http://cgal-discuss.949826.n4.nabble.com/meshing-a-simple-polygon-tp2309541p2310134.html>
Sent from the cgal-discuss mailing list archive <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
- [cgal-discuss] meshing a simple polygon, sara123, 08/01/2010
- Re: [cgal-discuss] meshing a simple polygon, Sebastien Loriot (GeometryFactory), 08/02/2010
- [cgal-discuss] boost 1.43, sara123, 08/02/2010
- Re: [cgal-discuss] boost 1.43, Sebastien Loriot (GeometryFactory), 08/02/2010
