Re: [cgal-discuss] Bug in "find_optimal_alpha" function of the class "Alpha_shape_2"
- To:
- Cc: "Sebastien Loriot (GeometryFactory)" <>
- Subject: Re: [cgal-discuss] Bug in "find_optimal_alpha" function of the class "Alpha_shape_2"
- Date: Mon, 02 Aug 2010 16:40:35 +0200
Dear Sebastien,
I have just tried what you suggested me and I can still observe the problem.
The program is the same as the one I sent you, I only changed the include "#include <CGAL/Exact_predicates_inexact_constructions_kernel.h>" to "#include <CGAL/Exact_predicates_exact_constructions_kernel.h>" and "typedef CGAL::Exact_predicates_inexact_constructions_kernel K" to "typedef CGAL::Exact_predicates_exact_constructions_kernel K".
Thank you for your help,
Best Regards,
Benoît
Le 30/07/2010 14:54, Sebastien Loriot (GeometryFactory) a écrit :
Can you please try with Exact_predicates_exact_constructions_kernel and
tell us whether you still observe the problem?
(this may be an floating point arithmetic problem)
Thanks.
S.
Benoît Presles wrote:
Hello Everybody,
I use the latest version of CGAL and I think a bug could be present in
the function "find_optimal_alpha" of the class "Alpha_shape_2".
- First, I use the function "find_optimal_alpha" to find the best
alpha to get 1 connected component.
- Second, I set this alpha.
- Third, I use the function "number_of_solid_components" to get the
number of solid components of A.
Sometimes, the program gives me 2 connected components instead of 1.
Attached, you can fine the c++ code (basically the same as in the
example) and a list of points for which the program doesn't work as
expected.
Best Regards,
Ben_P
- Re: [cgal-discuss] Bug in "find_optimal_alpha" function of the class "Alpha_shape_2", Benoît Presles, 08/02/2010
- Re: [cgal-discuss] Bug in "find_optimal_alpha" function of the class "Alpha_shape_2", Benoît Presles, 08/04/2010
- Re: [cgal-discuss] Bug in "find_optimal_alpha" function of the class "Alpha_shape_2", Sebastien Loriot (GeometryFactory), 08/05/2010
