cgal-discuss - Re: [cgal-discuss] Assertion: CGAL/Interval_nt.h:88: !(i>s)
  • To:
  • Subject: Re: [cgal-discuss] Assertion: CGAL/Interval_nt.h:88: !(i>s)
  • Date: Mon, 09 Aug 2010 20:43:47 +0200
Le 06/08/10 17:37, Bruce Duncan a écrit :
Sylvain Pion wrote:
Le 06/08/10 14:02, Bruce Duncan a écrit :
For one of the assertions I'm hitting, I've created what I hope is a
small testcase. The code and the output on my machine is attached.
The assertion means that an uninitialized variable has been used.
And indeed the plane equations in the Polyhedron of CGAL needs manual
construction. Seehttp://www.cgal.org/FAQ.html#polyhedron_normals .
I have tried to modify my program to use the Traits class as shown in
the example program.
I am now having trouble converting this Polyhedron to a Nef_polyhedron,
which I want to use for the boolean operations. Is this possible?
I haven't attached the compiler output this time, as it's very long.
Suffice to say it starts with "Nef_3/polyhedron_3_to_nef_3.h:218: error:
'class Vector_3' has no member named 'is_degenerate'"
What am I doing wrong?
I am not well versed enough into the Nef polyhedron to answer.
I hope someone else can follow up. In any case, I advice to send
as much of the error message as possible : I'm not sure it's
possible for anyone to see what's going wrong here.
Sylvain
