- To:
- Subject: Re: [cgal-discuss] Hilbert Sort on a User Defined Point
- Date: Mon, 09 Aug 2010 20:37:16 +0200
Le 09/08/10 18:48, Derek Basehore a écrit :
I'm looking to sort a vector of points using the hilbert_sort function.
The problem is that I have a user defined point. My attempts to implement
this so far have failed. Is there a way to use the traits mechanism
mentioned in the user manual to sort user defined (3D) points?
Yes.
What failed exactly in your attempts ?
Sylvain
- [cgal-discuss] Hilbert Sort on a User Defined Point, Derek Basehore, 08/09/2010
- Re: [cgal-discuss] Hilbert Sort on a User Defined Point, Sylvain Pion, 08/09/2010
- [cgal-discuss] Re: Hilbert Sort on a User Defined Point, Derek, 08/09/2010
- Re: [cgal-discuss] Re: Hilbert Sort on a User Defined Point, Sylvain Pion, 08/09/2010
- [cgal-discuss] Re: Hilbert Sort on a User Defined Point, Derek, 08/10/2010
- Re: [cgal-discuss] Re: Hilbert Sort on a User Defined Point, Sylvain Pion, 08/10/2010
- Re: [cgal-discuss] Re: Hilbert Sort on a User Defined Point, Andreas Fabri, 08/10/2010
