Re: [cgal-discuss] BUG: Surface_mesh_simplification/halfedge_collapse_Polyhedron_3.h
- To: , "Sebastien Loriot (GeometryFactory)" <>
- Cc:
- Subject: Re: [cgal-discuss] BUG: Surface_mesh_simplification/halfedge_collapse_Polyhedron_3.h
- Date: Fri, 13 Aug 2010 13:23:57 +0300
Quoting "Sebastien Loriot (GeometryFactory)"
> Lehtonen, Matti/HIIT wrote:
> > * Similar bug is located (most likely) in polyhedron_3::is_valid() too.
> From what I understand of your description, a single triangle seems to
> be filling the conditions of your bug report.
> However I already loaded a single triangle in Polyhedron and called
> is_valid. Do you have an example showing that bug in Polyhedron_3?
I have been using too short and bad wording. I have a C3T3 surface
<GROUND,AIR>
of GROUND sub-domain that is invalid as polyhedron (border were okay), before
writing to OFF file. But after read from OFF file, it were okay. See
http://www.iki.fi/m-matti-a.lehtonen/limited/Polyhedron_GROUND-DOMAIN.off
Lehtonen, Matti
Researcher, head programmer - Helsinki Institute for Information Technology
HIIT
http://www.hiit.fi/
Life is complex. It has real and imaginary parts.
- [cgal-discuss] BUG: Surface_mesh_simplification/halfedge_collapse_Polyhedron_3.h, Lehtonen, Matti/HIIT, 08/10/2010
- Re: [cgal-discuss] BUG: Surface_mesh_simplification/halfedge_collapse_Polyhedron_3.h, Sebastien Loriot (GeometryFactory), 08/10/2010
- <Possible follow-up(s)>
- Re: [cgal-discuss] BUG: Surface_mesh_simplification/halfedge_collapse_Polyhedron_3.h, Lehtonen, Matti/HIIT, 08/13/2010
