Re: [cgal-discuss] BUG: Surface_mesh_simplification/halfedge_collapse_Polyhedron_3.h
- To: , "Lehtonen, Matti/HIIT" <>
- Cc: , "Sebastien Loriot (GeometryFactory)" <>
- Subject: Re: [cgal-discuss] BUG: Surface_mesh_simplification/halfedge_collapse_Polyhedron_3.h
- Date: Fri, 13 Aug 2010 14:22:41 +0300
H!
Edge collapse were suffering segment fault with missing opposite halfedge in
code similar in example
http://www.cgal.org/Manual/3.5/examples/Surface_mesh_simplification/edge_collapse_constrained_polyhedron.cpp
When also an opposite half edge is checked for border at constraint map,then
this segment fault never happens.
Lehtonen, Matti
Quoting "Lehtonen, Matti/HIIT"
> Quoting "Sebastien Loriot (GeometryFactory)"
> > Lehtonen, Matti/HIIT wrote:
> > > * Similar bug is located (most likely) in polyhedron_3::is_valid() too.
> > From what I understand of your description, a single triangle seems to
> > be filling the conditions of your bug report.
> > However I already loaded a single triangle in Polyhedron and called
> > is_valid. Do you have an example showing that bug in Polyhedron_3?
> I have been using too short and bad wording. I have a C3T3 surface
> <GROUND,AIR>
> of GROUND sub-domain that is invalid as polyhedron (border were okay),
> before
> writing to OFF file. But after read from OFF file, it were okay. See
> http://www.iki.fi/m-matti-a.lehtonen/limited/Polyhedron_GROUND-DOMAIN.off
> Lehtonen, Matti
> Researcher, head programmer - Helsinki Institute for Information Technology
> HIIT
> http://www.hiit.fi/
> Life is complex. It has real and imaginary parts.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
HIIT
http://www.hiit.fi/
- [cgal-discuss] BUG: Surface_mesh_simplification/halfedge_collapse_Polyhedron_3.h, Lehtonen, Matti/HIIT, 08/10/2010
- Re: [cgal-discuss] BUG: Surface_mesh_simplification/halfedge_collapse_Polyhedron_3.h, Sebastien Loriot (GeometryFactory), 08/10/2010
- <Possible follow-up(s)>
- Re: [cgal-discuss] BUG: Surface_mesh_simplification/halfedge_collapse_Polyhedron_3.h, Lehtonen, Matti/HIIT, 08/13/2010
