- To:
- Subject: Re: [cgal-discuss] problems with TAUCS again
- Date: Thu, 19 Aug 2010 17:25:48 +0200
On Thursday 19 August 2010 17:10:12
wrote:
> Hi,
> I want to use Poisson algorithm from CGAL which requires TAUCS libray.
> All my code are in windows platform. When I install CGAL, I made it
> download the Taucs precompiled binaries. But I got a link error when I
> tried the example in the CGAL manual
> C:\Program Files\CGAL-3.6.1\auxiliary\taucs\lib\libtaucs-vc90-mt-gd.pdb :
> fatal error LNK1107: invalid or corrupt file: cannot read at 0x1B000
> Is any problem with the precomplied the taucs lib or other problems cause
> this error.
Maybe this file is really corrupted. As .pdb files are debugging symbols, try
to remove or rename it: you do not need debug symbols of libtaucs.
Laurent Rineau, PhD
- [cgal-discuss] problems with TAUCS again, wangruisheng, 08/19/2010
- Re: [cgal-discuss] problems with TAUCS again, Laurent Rineau (GeometryFactory), 08/19/2010
