- To:
- Subject: [cgal-discuss] TAUCS problems once more
- Date: Thu, 19 Aug 2010 17:53:03 +0200 (CEST)
Hi Laurent,
Thank you very much for your reply. I remove that file, but I got another
error
LINK : fatal error LNK1104: cannot open file 'libtaucs-vc90-mt-gd.pdb
Best regards,
Ruisheng
Hi,
I want to use Poisson algorithm from CGAL which requires TAUCS libray.
All my code are in windows platform. When I install CGAL, I made it download
the Taucs precompiled binaries. But I got a link error when I tried the
example in the CGAL manual
C:\Program Files\CGAL-3.6.1\auxiliary\taucs\lib\libtaucs-vc90-mt-gd.pdb :
fatal
error LNK1107: invalid or corrupt file: cannot read at 0x1B000
Is any problem with the precomplied the taucs lib or other problems cause this
error.
Thank you very much for your help!
Ruisheng
- [cgal-discuss] TAUCS problems once more, wangruisheng, 08/19/2010
- Re: [cgal-discuss] TAUCS problems once more, Laurent Rineau (GeometryFactory), 08/19/2010
