cgal-discuss - [cgal-discuss] CGAL 3d Mesh Triangulation. Facets with too many neighbors facets.
  • To:
  • Subject: [cgal-discuss] CGAL 3d Mesh Triangulation. Facets with too many neighbors facets.
  • Date: Fri, 20 Aug 2010 05:33:33 -0700 (PDT)
Hi everyone,
I am performing a 3d mesh triangulation for finite element analysis. In
order to perform the analysis I need to assign to each facet a corresponding
boundary pressure information. When doing so I sometimes need to use the
neighbours of a facets, and by neighbour I understand a facet that share a
common edge with the one in question. However I run into a problem, I expect
all facet to have either 0,1,2 or 3 neighbours, since a facet is a triangle
with 3 edges and I assume surface to be a smooth manifold, but I sometimes
get facets with 4,5 or even 7 facets. Did anybody run into this problem? Is
there normal, or is it due to rounding error or something similar?
http://img829.imageshack.us/img829/9066/permeabilitytoomanyneig.png
Thanks in advance,
Michal Parusinski
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-3d-Mesh-Triangulation-Facets-with-too-many-neighbors-facets-tp2332420p2332420.html
