cgal-discuss - Re: [cgal-discuss] CGAL 3d Mesh Triangulation. Facets with too many neighbors facets.
  • To:
  • Subject: Re: [cgal-discuss] CGAL 3d Mesh Triangulation. Facets with too many neighbors facets.
  • Date: Fri, 20 Aug 2010 16:39:46 +0200
mparusinski wrote:
Hi everyone,
Hi,
I am performing a 3d mesh triangulation for finite element analysis. In
order to perform the analysis I need to assign to each facet a corresponding
boundary pressure information. When doing so I sometimes need to use the
neighbours of a facets, and by neighbour I understand a facet that share a
common edge with the one in question.
If you are computing a 3D mesh, you get a partition of some volumes by tetrahedra.
In such a 3D structure, there is no reason why there would be a bound on the number of tetrahedra (and thus facets) incident to a given edge. You can get any number.
However I run into a problem, I expect
all facet to have either 0,1,2 or 3 neighbours, since a facet is a triangle
with 3 edges and I assume surface to be a smooth manifold,
This would indeed be the case if you were meshing a surface (2D object) using triangles.
but I sometimes
get facets with 4,5 or even 7 facets.
you can get more...
Best,
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
