cgal-discuss - Re: [cgal-discuss] CGAL-3.7-Beta: bug in demo/Mesh_3?
  • To:
  • Subject: Re: [cgal-discuss] CGAL-3.7-Beta: bug in demo/Mesh_3?
  • Date: Tue, 24 Aug 2010 13:32:25 +0200
Le mardi 24 août 2010 10:58:19,
a écrit :
> Hello,
> in the demo/Mesh_3 : the demo compiles correctly, but at execution time:
> 1. the choice of "implicit function" is not possible in the menu (I
> think it should as there is an implicit_function directory..).
> 2. And whatever you give him as input file (*.off, *.inr, *.inr.gz), it
> says : "File ... has not a known file format." (It's could be a problem
> due with the linking with CGAL_ImageIO ??)
Hi Emmanuel, in demo/Mesh_3/, can you try this patch?
Index: CMakeLists.txt
--- CMakeLists.txt (revision 58149)
+++ CMakeLists.txt (working copy)
@@ -95,7 +95,7 @@
# put plugins (which are shared libraries) at the same location as
# executable files
- set(LIBRARY_OUTPUT_PATH ${RUNTIME_OUTPUT_PATH})
+ set(CMAKE_LIBRARY_OUTPUT_DIRECTORY "${CMAKE_RUNTIME_OUTPUT_DIRECTORY}")
# prefix for Mesh_3 libs to avoid conflicts with Polyhedron demo
set(MESH_3_LIB_PREFIX "mesh_3_demo_")
The patched file is attached. Just copy it to replace
demo/Mesh_3/CMakeLists.txt
Laurent Rineau, PhD
# This is the CMake script for compiling the CGAL Mesh_3 demo.
project( Mesh_3_demo )
cmake_minimum_required(VERSION 2.4.5)
set(CMAKE_ALLOW_LOOSE_LOOP_CONSTRUCTS true)
#option(MESH_3_DEMO_ENABLE_FORWARD_DECL "In the Mesh_3 demo, enable " OFF)
#mark_as_advanced(MESH_3_DEMO_ENABLE_FORWARD_DECL)
if(COMMAND cmake_policy)
  cmake_policy(SET CMP0003 NEW)
endif(COMMAND cmake_policy)
# Include this package's headers first
include_directories( BEFORE ./ ./include ../../include )
# Add specific Find.cmake modules
set(CMAKE_MODULE_PATH ${CMAKE_MODULE_PATH} ${CMAKE_CURRENT_SOURCE_DIR}/cmake/modules )
# Find CGAL and CGAL Qt4
find_package(CGAL COMPONENTS Qt4 ImageIO)
include( ${CGAL_USE_FILE} )
# Find Qt4 itself
set( QT_USE_QTXML    TRUE )
set( QT_USE_QTMAIN   TRUE )
set( QT_USE_QTSCRIPT  TRUE )
set( QT_USE_QTOPENGL  TRUE )
find_package(Qt4)
# Find OpenGL
find_package(OpenGL)
# Find GLEW (for OpenGL-1.5 and OpenGL extensions)
find_package(GLEW)
# Find QGLViewer
if(QT4_FOUND)
  include(${QT_USE_FILE})
  find_package(QGLViewer )
endif(QT4_FOUND)
if(CGAL_Qt4_FOUND AND QT4_FOUND AND OPENGL_FOUND AND QGLVIEWER_FOUND)
  # Add directory containing implicit function plugin source files
  add_subdirectory("implicit_functions")
  if(GLEW_FOUND)
    include_directories ( ${GLEW_INCLUDE_DIR} )
    add_definitions(-DSCENE_SEGMENTED_IMAGE_GL_BUFFERS_AVAILABLE)
  else(GLEW_FOUND)
    message(STATUS "NOTICE: GLEW library is not found. 3D images rendering will not be available.")
  endif(GLEW_FOUND)
  include_directories ( ${QGLVIEWER_INCLUDE_DIR} )
  qt4_wrap_ui( UI_FILES ui_files/MainWindow.ui )
  qt4_wrap_ui( meshingUI_FILES  ui_files/Meshing_dialog.ui)
  qt4_wrap_ui( optimUI_FILES  ui_files/Smoother_dialog.ui ui_files/LocalOptim_dialog.ui)
  qt4_wrap_ui( ribUI_FILES  ui_files/Rib_dialog.ui)
  qt4_wrap_ui( funcUI_FILES  ui_files/Function_dialog.ui)
  include(AddFileDependencies)
  # Shared demo files directory
  set(DEMO_SRC_DIR "${CMAKE_CURRENT_SOURCE_DIR}/src/CGAL_demo")
  set(DEMO_H_DIR "${CMAKE_CURRENT_SOURCE_DIR}/include/CGAL_demo")
  qt4_generate_moc( "MainWindow.h" "${CMAKE_CURRENT_BINARY_DIR}/MainWindow_moc.cpp" )
  add_file_dependencies( MainWindow_moc.cpp "${CMAKE_CURRENT_SOURCE_DIR}/MainWindow.h" )
  qt4_generate_moc( "${DEMO_H_DIR}/Viewer.h" Viewer_moc.cpp )
  add_file_dependencies( Viewer_moc.cpp "${DEMO_H_DIR}/Viewer.h" )
  qt4_generate_moc( "${DEMO_H_DIR}/Scene.h" Scene_moc.cpp )
  add_file_dependencies( Scene_moc.cpp "${DEMO_H_DIR}/Scene.h" )
  qt4_generate_moc( "${DEMO_H_DIR}/Scene_item.h" Scene_item_moc.cpp )
  add_file_dependencies( Scene_item_moc.cpp "${DEMO_H_DIR}/Scene_item.h" )
  qt4_add_resources ( RESOURCE_FILES Mesh_3.qrc )
  qt4_automoc( Scene_polyhedron_item.cpp )
  qt4_automoc( Scene_polygon_soup.cpp )
  qt4_automoc( Scene_segmented_image_item.cpp )
  qt4_automoc( Scene_c3t3_item.cpp )
  qt4_automoc( Scene_implicit_function_item.cpp )
  qt4_automoc( Optimizer_thread.cpp )
  qt4_automoc( Meshing_thread.cpp )
  # executable files
  # AUXILIARY LIBRARIES
  set(VIEWER_LIB "${MESH_3_LIB_PREFIX}viewer")
  add_library(${VIEWER_LIB} SHARED
    ${DEMO_SRC_DIR}/Viewer.cpp Viewer_moc.cpp)
  target_link_libraries(${VIEWER_LIB} ${QGLVIEWER_LIBRARIES})
  set_target_properties(${VIEWER_LIB} PROPERTIES DEFINE_SYMBOL viewer_EXPORTS)
  set(SCENE_ITEM_LIB "${MESH_3_LIB_PREFIX}scene_item")
  add_library(${SCENE_ITEM_LIB} SHARED
    ${DEMO_SRC_DIR}/Scene_item.cpp
    Scene_item_moc.cpp
    ${DEMO_SRC_DIR}/Scene_item_with_display_list.cpp
    ${DEMO_SRC_DIR}/Plugin_helper.cpp)
  set_target_properties(${SCENE_ITEM_LIB} PROPERTIES DEFINE_SYMBOL scene_item_EXPORTS)
  set(SCENE_SEGMENTED_IMAGE_ITEM_LIB "${MESH_3_LIB_PREFIX}scene_segmented_image_item")
  add_library(${SCENE_SEGMENTED_IMAGE_ITEM_LIB} SHARED
    Scene_segmented_image_item.cpp Scene_segmented_image_item.moc)
  target_link_libraries(${SCENE_SEGMENTED_IMAGE_ITEM_LIB} ${SCENE_ITEM_LIB})
  set_target_properties(${SCENE_SEGMENTED_IMAGE_ITEM_LIB} PROPERTIES DEFINE_SYMBOL scene_segmented_image_item_EXPORTS)
  if(GLEW_FOUND)
    target_link_libraries(${SCENE_SEGMENTED_IMAGE_ITEM_LIB} ${GLEW_LIBRARIES})
  endif()
  set(SCENE_POLYHEDRON_ITEM_LIB "${MESH_3_LIB_PREFIX}scene_polyhedron_item")
  add_library(${SCENE_POLYHEDRON_ITEM_LIB} SHARED
    Scene_polyhedron_item.cpp Scene_polyhedron_item.moc)
  target_link_libraries(${SCENE_POLYHEDRON_ITEM_LIB} ${SCENE_ITEM_LIB})
  set_target_properties(${SCENE_POLYHEDRON_ITEM_LIB} PROPERTIES DEFINE_SYMBOL scene_polyhedron_item_EXPORTS)
  set(POLYGON_SOUP_LIB "${MESH_3_LIB_PREFIX}polygon_soup")
  add_library(${POLYGON_SOUP_LIB} SHARED
    Scene_polygon_soup.cpp Scene_polygon_soup.moc)
  target_link_libraries(${POLYGON_SOUP_LIB} ${SCENE_ITEM_LIB})
  set_target_properties(${POLYGON_SOUP_LIB} PROPERTIES DEFINE_SYMBOL polygon_soup_EXPORTS)
  set(SCENE_C3T3_ITEM_LIB "${MESH_3_LIB_PREFIX}scene_c3t3_item")
  add_library(${SCENE_C3T3_ITEM_LIB} SHARED
    Scene_c3t3_item.cpp Scene_c3t3_item.moc)
  target_link_libraries(${SCENE_C3T3_ITEM_LIB} ${SCENE_ITEM_LIB} ${QGLVIEWER_LIBRARIES} )
  set_target_properties(${SCENE_C3T3_ITEM_LIB} PROPERTIES DEFINE_SYMBOL scene_c3t3_item_EXPORTS)
  set(SCENE_IMPLICIT_FUNCTION_ITEM_LIB "${MESH_3_LIB_PREFIX}scene_implicit_function_item")
  add_library(${SCENE_IMPLICIT_FUNCTION_ITEM_LIB} SHARED
    Scene_implicit_function_item.cpp Scene_implicit_function_item.moc Color_ramp.cpp)
  target_link_libraries(${SCENE_IMPLICIT_FUNCTION_ITEM_LIB} ${SCENE_ITEM_LIB} ${QGLVIEWER_LIBRARIES} )
  set_target_properties(${SCENE_IMPLICIT_FUNCTION_ITEM_LIB} PROPERTIES DEFINE_SYMBOL scene_implicit_function_item_EXPORTS)
  add_definitions(-DUSE_FORWARD_DECL)
  add_definitions(-DQT_STATICPLUGIN)
    add_executable  ( Mesh_3 MainWindow.cpp
      Mesh_3.cpp
      ${DEMO_SRC_DIR}/Scene.cpp
      MainWindow_moc.cpp
      Scene_moc.cpp
      ${UI_FILES} ${RESOURCE_FILES} )
    add_to_cached_list( CGAL_EXECUTABLE_TARGETS Mesh_3 )
  # Link with Qt libraries
  target_link_libraries( Mesh_3 ${QT_LIBRARIES} )
  # Link with CGAL
  target_link_libraries( Mesh_3 ${CGAL_LIBRARIES} ${CGAL_3RD_PARTY_LIBRARIES} )
  # Link with libQGLViewer, OpenGL
  target_link_libraries( Mesh_3 ${QGLVIEWER_LIBRARIES} ${OPENGL_gl_LIBRARY} ${OPENGL_glu_LIBRARY} )
#  # Link with the scene_item library.
#  target_link_libraries( Mesh_3 scene_item )
  target_link_libraries( Mesh_3 ${VIEWER_LIB} )
  # PLUGINS #
  remove_definitions(-DQT_STATICPLUGIN)
  # polyhedron_demo_plugin is a macro copied from demo/Polyhedron/CMakeLists.txt
  macro(polyhedron_demo_plugin plugin_name plugin_implementation_base_name)
    list_split(option ARGN_TAIL ${ARGN} )
    if(NOT ${option} STREQUAL "EXCLUDE_FROM_ALL")
      set(other_sources ${ARGN})
      set(option "")
    else()
      set(other_sources ${ARGN_TAIL})
    endif()
    qt4_generate_moc( "${CMAKE_CURRENT_SOURCE_DIR}/${plugin_implementation_base_name}.cpp" ${plugin_implementation_base_name}.moc )
    add_file_dependencies( ${plugin_implementation_base_name}.moc "${CMAKE_CURRENT_SOURCE_DIR}/${plugin_implementation_base_name}.cpp" )
    add_library(${plugin_name} MODULE ${option} ${plugin_implementation_base_name}.moc ${plugin_implementation_base_name}.cpp ${other_sources})
    add_to_cached_list( CGAL_EXECUTABLE_TARGETS ${plugin_name} )
    # Link with Qt
    target_link_libraries( ${plugin_name} ${QT_LIBRARIES} )
    # Link with scene_item
    target_link_libraries( ${plugin_name} ${SCENE_ITEM_LIB})
    # Link with CGAL
    target_link_libraries( ${plugin_name} ${CGAL_LIBRARIES} ${CGAL_3RD_PARTY_LIBRARIES} )
  endmacro(polyhedron_demo_plugin)
  set(IO_IMAGE_PLUGIN_LIB "${MESH_3_LIB_PREFIX}io_image_plugin")
  polyhedron_demo_plugin(${IO_IMAGE_PLUGIN_LIB} Io_image_plugin)
  target_link_libraries(${IO_IMAGE_PLUGIN_LIB} ${SCENE_SEGMENTED_IMAGE_ITEM_LIB})
  if(GLEW_FOUND)
    target_link_libraries(${IO_IMAGE_PLUGIN_LIB} ${GLEW_LIBRARIES})
  endif()
  set(IO_OFF_PLUGIN_LIB "${MESH_3_LIB_PREFIX}io_off_plugin")
  polyhedron_demo_plugin(${IO_OFF_PLUGIN_LIB} Io_off_plugin)
  target_link_libraries(${IO_OFF_PLUGIN_LIB} ${SCENE_POLYHEDRON_ITEM_LIB} ${POLYGON_SOUP_LIB})
  set(IO_C3T3_PLUGIN_LIB "${MESH_3_LIB_PREFIX}io_c3t3_plugin")
  polyhedron_demo_plugin(${IO_C3T3_PLUGIN_LIB} Io_c3t3_plugin)
  target_link_libraries(${IO_C3T3_PLUGIN_LIB} ${SCENE_C3T3_ITEM_LIB})
  if ( EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/c3t3_rib_exporter_plugin.cpp" )
    set(C3T3_RIB_EXPORTER_PLUGIN_LIB "${MESH_3_LIB_PREFIX}c3t3_rib_exporter_plugin")
    polyhedron_demo_plugin(${C3T3_RIB_EXPORTER_PLUGIN_LIB} C3t3_rib_exporter_plugin ${ribUI_FILES})
    target_link_libraries(${C3T3_RIB_EXPORTER_PLUGIN_LIB} ${SCENE_C3T3_ITEM_LIB} ${VIEWER_LIB})
  endif()
  set(IO_IMPLICIT_FUNCTION_PLUGIN_LIB "${MESH_3_LIB_PREFIX}io_implicit_function_plugin")
  polyhedron_demo_plugin(${IO_IMPLICIT_FUNCTION_PLUGIN_LIB} Io_implicit_function_plugin ${funcUI_FILES})
  target_link_libraries(${IO_IMPLICIT_FUNCTION_PLUGIN_LIB} ${SCENE_IMPLICIT_FUNCTION_ITEM_LIB})
  set(MESH_3_PLUGIN_LIB "${MESH_3_LIB_PREFIX}mesh_3_plugin")
  polyhedron_demo_plugin(${MESH_3_PLUGIN_LIB} Mesh_3_plugin
                         Mesh_3_plugin_polyhedron_cgal_code.cpp
                         Mesh_3_plugin_image_cgal_code.cpp
                         Mesh_3_plugin_implicit_function_cgal_code.cpp
                         Meshing_thread.cpp
                         Scene_c3t3_item.moc
                         ${meshingUI_FILES})
  target_link_libraries(${MESH_3_PLUGIN_LIB}
                        ${OPENGL_glu_LIBRARY})
  set(MESH_3_OPTIMIZATION_PLUGIN_LIB "${MESH_3_LIB_PREFIX}mesh_3_optimization_plugin")
  polyhedron_demo_plugin(${MESH_3_OPTIMIZATION_PLUGIN_LIB} Mesh_3_optimization_plugin
                         Mesh_3_optimization_plugin_cgal_code.cpp
                         Scene_c3t3_item.moc
                         ${optimUI_FILES})
  target_link_libraries(${MESH_3_OPTIMIZATION_PLUGIN_LIB}
else (CGAL_Qt4_FOUND AND QT4_FOUND AND OPENGL_FOUND AND QGLVIEWER_FOUND)
  set(MESH_3_MISSING_DEPS "")
  if(NOT CGAL_Qt4_FOUND)
    set(MESH_3_MISSING_DEPS "the CGAL Qt4 library, ${MESH_3_MISSING_DEPS}")
  endif()
  if(NOT QT4_FOUND)
    set(MESH_3_MISSING_DEPS "Qt4, ${MESH_3_MISSING_DEPS}")
  endif()
  if(NOT OPENGL_FOUND)
    set(MESH_3_MISSING_DEPS "OpenGL, ${MESH_3_MISSING_DEPS}")
  endif()
  if(NOT QGLVIEWER_FOUND)
    set(MESH_3_MISSING_DEPS "QGLViewer, ${MESH_3_MISSING_DEPS}")
  endif()
  message(STATUS "NOTICE: This demo requires ${MESH_3_MISSING_DEPS}and will not be compiled.")
endif (CGAL_Qt4_FOUND AND QT4_FOUND AND OPENGL_FOUND AND QGLVIEWER_FOUND)
