Re: [cgal-discuss] questions about surface mesh, ellipsoidal approximation, and licences
- To:
- Subject: Re: [cgal-discuss] questions about surface mesh, ellipsoidal approximation, and licences
- Date: Wed, 25 Aug 2010 12:15:57 -0400
Hi Andreas,
thanks for your kind reply.
In the event that I wanted to negotiate in the future a commercial
licence that replaces the QPL one, would this be possible, and what
kind of cost would I be facing if so?
Best wishes,
Michel
On Wed, Aug 25, 2010 at 12:01 PM, Andreas Fabri
wrote:
> On 23/08/2010 16:20, Michel Audette wrote:
>> Dear CGAL developers and users,
>> Sorry if this appeared before, but I just rejoined CGAL users, and
>> I did not see my message on the list, so this submission may have gone
>> through before my membership.
>> I'd like to incorporate some CGAL functions into my research, but I
>> would like to find out more about licensing.
>> The website says that some classes are LGPL and some are QPL. I don't
>> plan on modifying the source code, but use it as is, like a black box.
>> Is the user given the choice for each, or are the licences set as one
>> or the other on a case-by-case basis?
> Hi Michel,
> It is on a case by case base, and the package overview page
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/packages.html
> gives this kind of information.
>> Moreover, I'm interested in the 3D surface mesh, and would like to
>> find out more... Does it produce a mesh that is water-tight? Moroever,
>> it seems not to produce slivers (triangles with small edges), which
>> has important implications for finite elements. Is this shape quality
>> based on a parameter of the algorithm, and does this high quality come
>> at a price in terms of distance to the underlying boundary?
>> Finally, a former student of mine used ellipsoid approximation in the
>> past, I believe Approximate_min_ellipsoid_d .
>> I would be interested in the licences of both of these. Can I use the
>> code freely in both of these cases?
> Free or not depends mainly what you do with it, and how free your own code
> is when you distribute it. The QPL is roughly as the GPL
> that is when you use CGAL and distribute your code which uses CGAL,
> then you must distribute your code also under an open source license.
> So you would probably not be allowed to integrate it in VolView,
> but you could wrap it so that it has the API of a vtk filter
> (with the wrapped code still having the CGAL and not the vtk license).
> Best regards,
> Andreas Fabri
>> Best wishes,
>> Michel
>> Michel Audette, Ph.D.
>> R& D Engineer,
>> Kitware Inc.,
>> Chapel Hill, N.C.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
R & D Engineer,
Kitware Inc.,
Chapel Hill, N.C.
- [cgal-discuss] questions about surface mesh, ellipsoidal approximation, and licences, Michel Audette, 08/20/2010
- <Possible follow-up(s)>
- [cgal-discuss] questions about surface mesh, ellipsoidal approximation, and licences, Michel Audette, 08/23/2010
- Re: [cgal-discuss] questions about surface mesh, ellipsoidal approximation, and licences, Monique Teillaud, 08/23/2010
- Re: [cgal-discuss] questions about surface mesh, ellipsoidal approximation, and licences, Andreas Fabri, 08/25/2010
- Re: [cgal-discuss] questions about surface mesh, ellipsoidal approximation, and licences, Michel Audette, 08/25/2010
