cgal-discuss - Re: [cgal-discuss] Largest Empty Circle with Voronoi
  • To: <>
  • Cc: <>
  • Subject: Re: [cgal-discuss] Largest Empty Circle with Voronoi
  • Date: Thu, 26 Aug 2010 10:04:05 +0530
  • Organization: Winner Technologies
Dear Monique
Thanx for the suggestion i will try to do that.
----- Original Message ----- From: "Monique Teillaud" <>
To:
Sent: Wednesday, August 25, 2010 6:10 PM
Hi Naresh
You can compute this easily with CGAL:
First, compute the Delaunay triangulation of the points.
Then, iterate on all the finite faces of the triangulation.
For each finite face f
- compute its circumcenter c
- locate c in the triangulation (to speed up things, you can give one vertex of f as starting hint for the point location)
if the face returned by locate(c,hint) is finite, then the circumcenter c lies in the convex hull of the points, so, f is a candidate
- if f is such a candidate face, compute its squared circumradius
keep only the face with minimum squared circumradius
The CGAL manual (chapter 2D triangulation, together with a few things from the kernel) shows every basic function to do this.
Best regards,
Monique Teillaud
naresh wrote:
Dear Sebastien
Actually i am trying to find largest inscribed circle from pointset or may be counter sets in 2D. in wikipedia and google i read voronoi diagram can my solve problem using largest empty circle very easily but not got any implmentation or any good papers.
Any idea how to do with CGAL ?
thanx in advance.
Naresh
----- Original Message ----- From: "Sebastien Loriot (GeometryFactory)" <>
To:
Sent: Wednesday, August 25, 2010 5:14 PM
naresh wrote:
Hi
How can i find Larget Empty Circle with centered withthin their convex hull ?
Are you looking for the functions circumcenter and squared_radius?
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_23_ref/Function_circumcenter.html#Cross_link_anchor_398
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_23_ref/Function_squared_radius.html#Cross_link_anchor_459
S.
I checked the code but nothing found. While LEDA has some implementation. Does CGAL have anything ?
Naresh
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
