cgal-discuss - Re: [cgal-discuss] New bug in Alpha_shape_2 computation ?
  • To:
  • Cc: "Sebastien Loriot (GeometryFactory)" <>
  • Subject: Re: [cgal-discuss] New bug in Alpha_shape_2 computation ?
  • Date: Thu, 26 Aug 2010 10:41:58 +0200
Hello Everybody,
I think a new bug could be present in the "Alpha_shape_2" class (the
problem can be reproduced by using the list of points "fin" attached
in this email).
First, I compute the alpha shape (GENERAL MODE).
Second, I print the segments which belongs to the alpha shape.
Third, I print the points which belongs to the alpha shape
(Alpha_shape_vertices_iterator).
The problem is that I get too many points printed, for example the
point (60,50) doesn't belong to the alpha shape but is printed.
Output of the program:
Reading 11 points from file
Alpha Shape computed
7 alpha shape edges
7 0 4 4
4 4 1 0
0 0 1 0
1 0 2.5 0
2.5 0 4.5 0
4.5 0 7 0
16 16 20 20
as_it=4.5 0
as_it=2.5 0
as_it=4 4
as_it=7 0
as_it=1 0
as_it=0 0
as_it=8 12
as_it=16 16
as_it=20 20
as_it=40 40
as_it=60 50
It behaves as expected, vertices printed are either REGULAR or SINGULAR
in GENERAL mode and REGULAR in REGULARIZED mode.
Maybe I don't understand something but in my point of view, in both cases (GENERAL or REGULARIZED mode), the vertices printed with "Alpha_shape_vertices_iterator" should be the same as the one printed with "Alpha_shape_edges_iterator" and it is not the case here.
Thank you very much for your help,
Ben_P
S.
