- To:
- Subject: Re: [cgal-discuss] New bug in Alpha_shape_2 computation ?
- Date: Thu, 26 Aug 2010 10:52:58 +0200
Benoît Presles wrote:
A vertex is singular if it's in the alpha complex butHello Everybody,
I think a new bug could be present in the "Alpha_shape_2" class (the
problem can be reproduced by using the list of points "fin" attached
in this email).
First, I compute the alpha shape (GENERAL MODE).
Second, I print the segments which belongs to the alpha shape.
Third, I print the points which belongs to the alpha shape
(Alpha_shape_vertices_iterator).
The problem is that I get too many points printed, for example the
point (60,50) doesn't belong to the alpha shape but is printed.
Output of the program:
Reading 11 points from file
Alpha Shape computed
7 alpha shape edges
7 0 4 4
4 4 1 0
0 0 1 0
1 0 2.5 0
2.5 0 4.5 0
4.5 0 7 0
16 16 20 20
as_it=4.5 0
as_it=2.5 0
as_it=4 4
as_it=7 0
as_it=1 0
as_it=0 0
as_it=8 12
as_it=16 16
as_it=20 20
as_it=40 40
as_it=60 50
It behaves as expected, vertices printed are either REGULAR or SINGULAR
in GENERAL mode and REGULAR in REGULARIZED mode.
Maybe I don't understand something but in my point of view, in both cases (GENERAL or REGULARIZED mode), the vertices printed with "Alpha_shape_vertices_iterator" should be the same as the one printed with "Alpha_shape_edges_iterator" and it is not the case here.
no incident simplex is in the alpha complex.
If you only want to have vertices that are on the boundary but not
singular, you need to use either the REGULARIZED mode (it was designed
for this purpose I guess) or if you need to use the GENERAL mode, just
consider regular vertices.
S.
Thank you very much for your help,
Ben_P
S.
- [cgal-discuss] New bug in Alpha_shape_2 computation ?, Benoît Presles, 08/25/2010
- Re: [cgal-discuss] New bug in Alpha_shape_2 computation ?, Sebastien Loriot (GeometryFactory), 08/26/2010
- Re: [cgal-discuss] New bug in Alpha_shape_2 computation ?, Benoît Presles, 08/26/2010
