- To:
- Subject: [cgal-discuss] Triangulation to polygon
- Date: Mon, 30 Aug 2010 17:01:00 -0700 (PDT)
Hello,
I'm a new user of CGAL, and I'm trying to triangulate a set of 2D points to
closed polygons, without holes. After the triangulation I would like to
retrieve the points that form each triangulated polygon in a
counter-clockwise manner, and in a way that there is no crossing of the
polygons lines. Using one of the examples I can triangulate the points, but
cannot transform it to a list with the vertices of each polygon. Is there a
way to do that?
Thank you
Ivan
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Triangulation-to-polygon-tp2400873p2400873.html
- [cgal-discuss] Triangulation to polygon, Tunguska, 08/31/2010
- Re: [cgal-discuss] Triangulation to polygon, Sebastien Loriot (GeometryFactory), 08/31/2010
