cgal-discuss - Re: [cgal-discuss] How to improve the speed of polygons offsetting in CGAL?
  • To:
  • Subject: Re: [cgal-discuss] How to improve the speed of polygons offsetting in CGAL?
  • Date: Mon, 30 Aug 2010 13:17:00 -0300
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:content-type; b=SrsXth3rcY/m3y/25lpcv28vClBg2WH2O0M4PZ6R0eDj6zbtSIVB2LcMPfXNBk9bh/ hZaaBsZ1Mu+/MFtFxS5/Sr9ej7XcTs7REyP0dmOKEVqH4bLSqWwlnEIVKRWX+F0it9/q 1wGN7Di7MstGlWr1gEBMRJzQzRFZGA8qP30So=
Hi Ben,
> Hi Y'all,
> Fernando would be the expert on computation time, but...if the goal is an
> offset, an alternative to a straight skeleton would be to do a 'buffer' type
> operation, e.g. construct the offset curves piece-wise, dump them in an
> arrangement, and use the arrangement to find the interior.
FWIW, in CGAL 3.6, when you use the API that constructs offset curves
directly (that is, when the straight skeleton is constructed under the
hood), the skeleton is created only *partially*, just far enough to
contain the offsets at the given distance.
AFAICT this procedure should result in an effective running time even
faster then using an arrangement.
OTOH, if the *entire* skeleton is constructed, this can take up much
much more time.
Best
Fernando Cacciola
SciSoft Consulting, Founder
http://www.scisoft-consulting.com
