cgal-discuss - Re: [cgal-discuss] How to improve the speed of polygonsoffsettingin CGAL?
  • To:
  • Subject: Re: [cgal-discuss] How to improve the speed of polygonsoffsettingin CGAL?
  • Date: Tue, 31 Aug 2010 16:35:17 +0800
Hi,thank you for your reply.i have done that as you said,#define _SECURE_SCL 0
#define NDEBUG are in the first line and second line before other codes,but
the speed is the same,it doesn't change at all. what should i do now?please
give me help. The .cpp file and the data are attached in the email.
Best regards!
------------------ 原始邮件 ------------------
>From: "Laurent Rineau (GeometryFactory)"
>Reply-To:
>To:
>CGAL?
>Date: Tue, 31 Aug 2010 10:06:35 +0200
>On Tuesday 31 August 2010 03:20:01 罗恒 wrote:
>> Dear Fernando Cacciola,
>> Thank you for your reply.I have defined _SECURE_SCL=0 NDEBUG as
>> #define _SECURE_SCL 0 #define NDEBUG in the main.cpp attached in the
>> email,but the speed doesnot change at all.What is the reason? Could you
>> give me some detail instruction. Best regards!
>You must put those macro definitions at the very top of your .cpp file,
>before
>the first #include
>Laurent Rineau, PhD
>R&D Engineer at GeometryFactory http://www.geometryfactory.com/
>Release Manager of the CGAL Project http://www.cgal.org/
>You are currently subscribed to cgal-discuss.
>To unsubscribe or access the archives, go to
>https://lists-sop.inria.fr/wws/info/cgal-discuss
