- To:
- Subject: [cgal-discuss] lib-gmp hang with CGAL bezier curves on OS X
- Date: Fri, 24 Sep 2010 14:21:00 -0400
Hi Y'all,
I seem to be hitting a configuration problem when using CGAL. Here are the configuration details:
- CGAL 3.4
- The problem occurs on OS X, but not Linux.
- The problem occurs whether I use 10.6 (which defaults to GCC 4.2) or 10.5 (where I have forced GCC 4.2 in a few places, but others may fall through).
- CGAL has -frounding-math set, as expected.
- libgmp and libmpfr pass their self checks.
But...when I go to convert a quite trivial cubic bezier to its monotone sub-curves (as part of using the arrangement of bezier curves) I seem to hang in gmp.
Are there known configuration issues with gmp and CORE on OS X, particularly on 10.6?
Thanks!
Ben
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] lib-gmp hang with CGAL bezier curves on OS X, Ben Supnik, 09/24/2010
- [cgal-discuss] Re: lib-gmp hang with CGAL bezier curves on OS X, Ben Supnik, 09/26/2010
