- To:
- Subject: [cgal-discuss] Re: lib-gmp hang with CGAL bezier curves on OS X
- Date: Sun, 26 Sep 2010 10:53:12 -0400
Hi Y'all,
Follow-up in case anyone else hits this...it turns out that if you try to build gmp-4.3.1 on OS X for multiple architectures on a 64-bit Intel Mac, the resulting libraries will be buggy for all but one architecture. I don't think this is a gmp bug so much as a design limitation in how the library is structured. The build will pass its own make check tests, but then produce incorrect results in a 32-bit app.
It became clear that the bug was in gmp and not CGAL when I turned on full gmp debugging and gmp's internal assertions started firing off.
cheers
Ben
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] lib-gmp hang with CGAL bezier curves on OS X, Ben Supnik, 09/24/2010
- [cgal-discuss] Re: lib-gmp hang with CGAL bezier curves on OS X, Ben Supnik, 09/26/2010
