cgal-discuss - Re: [cgal-discuss] On rendering of Polyhedron in CGAL 3.3
  • To:
  • Subject: Re: [cgal-discuss] On rendering of Polyhedron in CGAL 3.3
  • Date: Sun, 26 Sep 2010 12:43:02 +0200
Le dimanche 26 septembre 2010 11:42:00, kyewong a écrit :
> Hi all
> I've found a problem when rendering Polyhedron in opengl environment:
> When the number of vertices of the mesh rendered is big, then it'll be very
> slow when manipulating it (translate, rotation or scale) in the window,
> wheras i've found that the manipulation in other software(eg. meshlab) for
> the same mesh is much faster.
You probably did not use OpenGL display lists. You need to, if you want good
performances.
Laurent Rineau, PhD
