- To:
- Subject: Re: Re: [cgal-discuss] Render a Polyhedron_3 using OpenGL vertex arrays
- Date: Tue, 28 Sep 2010 14:44:06 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=uiV9ce0piCFzhIwkIdO9C1+61WxNDQOBi2i3TwwTQ1STGjjW6yW4ggLR9FZ2UzU9Gk fUrXxp4qUqzEuqubBGbhWsXpmf2cOI8rHWeLhAyQ2XlWBXh8xChSKIHb09DRYzKxiTru 3nElD8Q6K5x/2QgBwCe0PnpY6nCQpwfH8Sv1Y=
Sorry I forgot to post the original problem and solution:
https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2007-12/msg00053.html
Currently when i wanna use the OpenGL vertex arrays i have to copy the data into a separate new array for using glVertexPointer, which seems a little bit stupid...
On Tue, Sep 28, 2010 at 2:30 PM, <> wrote:
Has anyone any better idea on solving this problem pls?
'cos the "CGAL::HalfedgeDS_vector" for defining Polyhedron will disable some
operations such as deleting elements(vertices or faces).
What if "CGAL::HalfedgeDS_default" must be used?
Thanks!
Kye Wong
- Re: Re: [cgal-discuss] Render a Polyhedron_3 using OpenGL vertex arrays, wangk0705, 09/28/2010
- Re: Re: [cgal-discuss] Render a Polyhedron_3 using OpenGL vertex arrays, Kye Wong, 09/28/2010
