- To: <>
- Subject: RE: [cgal-discuss] Operator Overloading problem for Vector in Gmpzf Kernel
- Date: Mon, 4 Oct 2010 17:38:20 +0530
Dear Marc,
Thanks, It works even with CGAL::Gmpq, after converting types in normal
calculation.
With regards,
Bose
-----Original Message-----
[mailto:]
Sent: Monday, October 04, 2010 2:46 PM
To:
Kernel
Wow, you seem to be out of luck.
Nef_* looks very limited in the kernels it accepts (basically only those
where the number type is a quotient), and because the
Algebraic_structure_traits doesn't provide a default trivial gcd for field
types, you can't even provide a Fraction_trait for CORE::Expr and pretend
it is a quotient (or use a CGAL::Quotient<CORE::Expr>).
typedef CGAL::Simple_cartesian<CGAL::Quotient<CGAL::Gmpz> > Kernel;
may compile, though the square root will be far from accurate.
An Sqrt_extension of Gmpq looks promizing, but it also seems to be missing
required pieces.
You may be able to convert back and forth between types, say:
n = n / Kernel::FT(CGAL::sqrt(CGAL::to_double(n.squared_length())));
if you don't mind the lack of accuracy.
On Mon, 4 Oct 2010, S K BOSE wrote:
> Dear All,
> Here is my small extracted code. I want to use both Polyhedron_3 and Nef
> Polyhedra.
> #include <CGAL/Exact_predicates_exact_constructions_kernel_with_sqrt.h>
> #include <CGAL/Polyhedron_3.h>
> #include <CGAL/Nef_polyhedron_3.h>
> typedef CGAL::Exact_predicates_exact_constructions_kernel_with_sqrt
Kernel;
> typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
> typedef CGAL::Nef_polyhedron_3<Kernel> Nef_polyhedron;
> typedef Kernel::Point_3 Point_3;
> typedef Polyhedron::Facet_iterator Facet_iterator;
> typedef Polyhedron::Halfedge_around_facet_circulator HF_circulator;
> typedef Kernel::Vector_3 Vector;
> int main() {
> Point_3 p( 1.0, 0.0, 0.0);
> Point_3 q( 0.0, 1.0, 0.0);
> Point_3 r( 0.0, 0.0, 1.0);
> Point_3 s( 0.0, 0.0, 0.0);
> Polyhedron P;
> P.make_tetrahedron( p, q, r, s);
> Nef_polyhedron N(P);
> //...........do some boolean operation
> if(N.is_simple())
> N.convert_to_Polyhedron(P);
> Facet_iterator f;
> for(f = P.facets_begin(); f != P.facets_end();f++)
> HF_circulator he = f->facet_begin();
> HF_circulator end = he;
> CGAL_For_all(he,end)
> const Point_3& prev = he->prev()->vertex()->point();
> const Point_3& curr = he->vertex()->point();
> const Point_3& next = he->next()->vertex()->point();
> //Vector n = CGAL::cross_product(next-curr,prev-curr);
> // n = n / CGAL::sqrt(n.squared_length());
> Vector n = CGAL::unit_normal(prev,curr,next);
> a) If I use "Exact_predicates_exact_constructions_kernel_with_sqrt", it
> gives error in decomposer(h.b(),num,denom) from Nef_S2/Normalizing.h like
> 1>G:\cgal\CGAL-3.7-beta1\include\CGAL/Nef_S2/Normalizing.h(306) : error
> C2064: term does not evaluate to a function taking 3 arguments
> 1>G:\cgal\CGAL-3.7-beta1\include\CGAL/Nef_S2/Normalizing.h(307) : error
> C2676: binary '*=' : 'CGAL::Null_tag' does not define this operator or a
> conversion to a type acceptable to the predefined operator
> b) If I use "Exact_predicates_exact_constructions_kernel", it gives the
same
> old problem as I was getting with homogeneous
> G:\cgal\CGAL-3.7-beta1\include\CGAL/Kernel/function_objects.h(1878) :
error
> C2678: binary '/' : no operator found which takes a left-hand operand of
> type 'CGAL::Vector_3<R_>' (or there is no acceptable conversion) -----
> c) If I use "Exact_predicates_inexact_constructions_kernel", it gives
> G:\cgal\CGAL-3.7-beta1\include\CGAL/Nef_3/Bounding_box_3.h(89) : error
> C2039: 'lo' : is not a member of 'CGAL::Box_intersection_d::Box_d<NT_,N>'
> In this context what should be my kernel. My compiler is Microsoft Visual
> Studio 2005
> With regards,
> Bose
> From: Marc Glisse
> [mailto:]
> Sent: Tuesday, September 21, 2010 7:01 PM
> To:
Gmpzf
> Kernel
> On Tue, 21 Sep 2010, S K BOSE wrote:
>> Thanks for reply. As Marc mentioned it is the problem for homogeneous
>> Vector, But if I use Exact_predicates_exact_constructions_kernel (which I
>> feel it is Cartesian) it gives same problem. Same problem for Gmpq kernel
>> also (as what Bernd suggested).
> If you really need sqrt, you want either an approximate kernel
> (Exact_predicates_inexact_constructions_kernel may work) or an exact
> kernel that can handle it
> (Exact_predicates_exact_constructions_kernel_with_sqrt).
- RE: [cgal-discuss] Operator Overloading problem for Vector in Gmpzf Kernel, S K BOSE, 10/04/2010
- RE: [cgal-discuss] Operator Overloading problem for Vector in Gmpzf Kernel, Marc Glisse, 10/04/2010
