cgal-discuss - Re: [cgal-discuss] Assertion: CGAL/Interval_nt.h:88: !(i>s)
  • To:
  • Subject: Re: [cgal-discuss] Assertion: CGAL/Interval_nt.h:88: !(i>s)
  • Date: Mon, 4 Oct 2010 15:29:50 +0100
  • Organization: School of Engineering, University of Edinburgh
On Lunes 09 Agosto 2010 19:43:47 Sylvain Pion escribió:
> Le 06/08/10 17:37, Bruce Duncan a écrit :
> > Sylvain Pion wrote:
> >> Le 06/08/10 14:02, Bruce Duncan a écrit :
> >>> For one of the assertions I'm hitting, I've created what I hope is a
> >>> small testcase. The code and the output on my machine is attached.
> >> The assertion means that an uninitialized variable has been used.
> >> And indeed the plane equations in the Polyhedron of CGAL needs manual
> >> construction. Seehttp://www.cgal.org/FAQ.html#polyhedron_normals .
> > I have tried to modify my program to use the Traits class as shown in
> > the example program.
> > I am now having trouble converting this Polyhedron to a Nef_polyhedron,
> > which I want to use for the boolean operations. Is this possible?
> > I haven't attached the compiler output this time, as it's very long.
> > Suffice to say it starts with "Nef_3/polyhedron_3_to_nef_3.h:218: error:
> > 'class Vector_3' has no member named 'is_degenerate'"
> > What am I doing wrong?
> I am not well versed enough into the Nef polyhedron to answer.
> I hope someone else can follow up. In any case, I advice to send
> as much of the error message as possible : I'm not sure it's
> possible for anyone to see what's going wrong here.
Hi,
Sorry for the delay in replying.
I have attached my test case and the compiler output. The code compiles if
line 20 is changed from Polyhedron_traits_with_normals_3 to just
Polyhedron_traits_3.
I looked at the difference between CGAL/Polyhedron_traits_3.h and
CGAL/Polyhedron_traits_with_normals_3.h. This hunk seemed interesting (line
32):
- typedef typename Kernel::Plane_3 Plane_3;
+ typedef typename Kernel::Vector_3 Plane_3;
I changed the code to:
typedef typename Kernel::Vector_3 Vector_3;
and it seems to compile. Is this a bug in CGAL? Perhaps the author intended
both Plane_3 and Vector_3 to be defined?
Thanks,
Bruce
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Extended_homogeneous.h>
#include <CGAL/Quotient.h>
#include <CGAL/Gmpz.h>
#include <CGAL/Gmpzf.h>
#include <CGAL/Nef_polyhedron_3.h>
#include <CGAL/Polyhedron_traits_with_normals_3.h>
#include <CGAL/Polyhedron_traits_3.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Nef_polyhedron_iostream_3.h>
#include <CGAL/IO/Polyhedron_VRML_2_ostream.h>
#include <CGAL/centroid.h>
#include <list>
#include <fstream>
#include <iostream>
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
//typedef CGAL::Homogeneous<double> Kernel;
//typedef CGAL::Extended_homogeneous<CGAL::Gmpz> Kernel;
typedef CGAL::Polyhedron_traits_with_normals_3<Kernel> Traits;
//typedef CGAL::Polyhedron_traits_3<Kernel> Traits;
typedef CGAL::Polyhedron_3<Traits> Polyhedron;
typedef CGAL::Nef_polyhedron_3<Kernel> Nef_polyhedron;
typedef Kernel::Direction_3 Direction;
typedef Kernel::Point_3 Point_3;
struct Normal_vector {
    template <class Facet>
    typename Facet::Plane_3 operator()( Facet& f) {
        typename Facet::Halfedge_handle h = f.halfedge();
        // Facet::Plane_3 is the normal vector type. We assume the
        // CGAL Kernel here and use its global functions.
        return CGAL::cross_product(
            h->next()->vertex()->point() - h->vertex()->point(),
            h->next()->next()->vertex()->point() - h->next()->vertex()->point());
int main() {
    Point_3 p( 1.0, 0.0, 0.0);
    Point_3 q( 0.0, 1.0, 0.0);
    Point_3 r( 0.0, 0.0, 1.0);
    Point_3 s( 0.0, 0.0, 0.0);
    Polyhedron P;
    P.make_tetrahedron( p, q, r, s);
    Nef_polyhedron N(P);
    Polyhedron P1;
    N.convert_to_polyhedron(P1);
//    std::transform(P1.facets_begin(), P1.facets_end(), P1.planes_begin(),
//                   Normal_vector());
    Polyhedron::Facet_const_iterator fi = P1.facets_begin();
    std::cerr << "Facet... " << &fi << std::endl;
    std::cerr << "fi->plane(): " << fi->plane() << std::endl;
    //Direction d1(fi->plane());
    //++fi;
    //std::cout << (d1 == Direction(fi->plane())) << std::endl;
    return 0;
In file included from /home/bduncan/opt/include/CGAL/Nef_polyhedron_3.h:63,
from testcase.cpp:6:
/home/bduncan/opt/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h: In function
‘void CGAL::polyhedron_3_to_nef_3(Polyhedron_&, SNC_structure&) [with
Polyhedron_ =
CGAL::Polyhedron_3<CGAL::Polyhedron_traits_with_normals_3<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::Simple_cartesian<CGAL::Interval_nt<false> >,
CGAL::Cartesian_converter<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > > >,
CGAL::Polyhedron_items_3, CGAL::HalfedgeDS_default, std::allocator<int> >,
SNC_structure =
CGAL::SNC_structure<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > >,
CGAL::SNC_indexed_items, bool>]’:
/home/bduncan/opt/include/CGAL/Nef_polyhedron_3.h:554: instantiated from
‘CGAL::Nef_polyhedron_3<K, I, Mk>::Nef_polyhedron_3(CGAL::Polyhedron_3<T1,
T2, T3, T4>&) [with T1 =
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > > >, T2 =
CGAL::Polyhedron_items_3, T3 = CGAL::HalfedgeDS_default, T4 =
std::allocator<int>, Kernel_ =
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > >, Items_ =
CGAL::SNC_indexed_items, Mark_ = bool]’
testcase.cpp:47: instantiated from here
/home/bduncan/opt/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h:216: error:
‘const class
CGAL::Vector_3<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > > >’ has no
member named ‘is_degenerate’
/home/bduncan/opt/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h:218: error:
‘const class
member named ‘has_on’
/home/bduncan/opt/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h:221: error:
‘const class
/home/bduncan/opt/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h:223: error:
‘const class
/home/bduncan/opt/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h:231: error:
‘const class
member named ‘opposite’
/home/bduncan/opt/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h:232: error: no
matching function for call to
‘CGAL::Sphere_circle<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
>::Sphere_circle(CGAL::Vector_3<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > > >&)’
/home/bduncan/opt/include/CGAL/Nef_S2/Sphere_circle.h:96: note: candidates
are: CGAL::Sphere_circle<R>::Sphere_circle(CGAL::Sphere_circle<R>, const
CGAL::Sphere_point<R>&) [with R_ =
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > >]
/home/bduncan/opt/include/CGAL/Nef_S2/Sphere_circle.h:92: note:
CGAL::Sphere_circle<R>::Sphere_circle(const typename R_::RT&, const
typename R_::RT&, const typename R_::RT&) [with R_ =
/home/bduncan/opt/include/CGAL/Nef_S2/Sphere_circle.h:84: note:
CGAL::Sphere_circle<R>::Sphere_circle(const typename R_::Plane_3&) [with R_
= CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
/home/bduncan/opt/include/CGAL/Nef_S2/Sphere_circle.h:61: note:
CGAL::Sphere_circle<R>::Sphere_circle(const CGAL::Sphere_point<R>&, const
/home/bduncan/opt/include/CGAL/Nef_S2/Sphere_circle.h:58: note:
CGAL::Sphere_circle<R>::Sphere_circle() [with R_ =
/home/bduncan/opt/include/CGAL/Nef_S2/Sphere_circle.h:31: note:
/home/bduncan/opt/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h:258: error:
‘const class
/home/bduncan/opt/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h:260: error:
‘const class
/home/bduncan/opt/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h:263: error:
‘const class
/home/bduncan/opt/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h:265: error:
‘const class
/home/bduncan/opt/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h:275: error:
‘const class
/home/bduncan/opt/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h:276: error: no
/home/bduncan/opt/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h:278: error:
‘class CGAL::Vector_3<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
/home/bduncan/opt/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h: In member
function ‘typename Facet_::Plane_3 CGAL::Facet_plane_3::operator()(Facet_&)
[with Facet_ =
CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Polyhedron_traits_with_normals_3<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>,
std::allocator<int> >, CGAL::Boolean_tag<true>,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > > > > > >]’:
/usr/include/c++/4.4/bits/stl_algo.h:4703: instantiated from ‘_OIter
std::transform(_IIter, _IIter, _OIter, _UnaryOperation) [with _IIter =
CGAL::internal::In_place_list_iterator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Polyhedron_traits_with_normals_3<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > > > > > >,
std::allocator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Polyhedron_traits_with_normals_3<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > > > > > > > >,
_OIter =
CGAL::Iterator_project<CGAL::internal::In_place_list_iterator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Polyhedron_traits_with_normals_3<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::Project_plane<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Polyhedron_traits_with_normals_3<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > > > > > > >, int,
int, int, int>, _UnaryOperation = CGAL::Facet_plane_3]’
/home/bduncan/opt/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h:164:
instantiated from ‘void CGAL::polyhedron_3_to_nef_3(Polyhedron_&,
SNC_structure&) [with Polyhedron_ =
SNC_structure =
/home/bduncan/opt/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h:70: error: no
‘CGAL::Vector_3<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
>::Vector_3(const
CGAL::Point_3<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::Facet_plane_3::operator()(Facet_&) [with Facet_ =
>]::Vector)’
/home/bduncan/opt/include/CGAL/Vector_3.h:96: note: candidates are:
CGAL::Vector_3<R_>::Vector_3(const typename R_::RT&, const typename R_::RT&,
const typename R_::RT&, const typename R_::RT&) [with R_ =
/home/bduncan/opt/include/CGAL/Vector_3.h:89: note:
CGAL::Vector_3<R_>::Vector_3(const CGAL::Null_vector&) [with R_ =
/home/bduncan/opt/include/CGAL/Vector_3.h:86: note:
CGAL::Vector_3<R_>::Vector_3(const typename R_::Line_3&) [with R_ =
/home/bduncan/opt/include/CGAL/Vector_3.h:83: note:
CGAL::Vector_3<R_>::Vector_3(const typename R_::Ray_3&) [with R_ =
/home/bduncan/opt/include/CGAL/Vector_3.h:80: note:
CGAL::Vector_3<R_>::Vector_3(const typename R_::Segment_3&) [with R_ =
/home/bduncan/opt/include/CGAL/Vector_3.h:77: note:
CGAL::Vector_3<R_>::Vector_3(const typename R_::Point_3&, const typename
R_::Point_3&) [with R_ =
/home/bduncan/opt/include/CGAL/Vector_3.h:74: note:
CGAL::Vector_3<R_>::Vector_3(const typename R_::Kernel_base::Vector_3&) [with
R_ = CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
/home/bduncan/opt/include/CGAL/Vector_3.h:72: note:
CGAL::Vector_3<R_>::Vector_3() [with R_ =
/home/bduncan/opt/include/CGAL/Vector_3.h:39: note:
>::Vector_3(const
_OIter =
SNC_structure =
/home/bduncan/opt/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h:73: error: no
>::Vector_3(const
>]::Vector)’
>::Vector_3(const
Attachment: signature.asc
Description: This is a digitally signed message part.
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
